HTC Thunderbolt Kickstand Replacement
    1. HTC Thunderbolt Kickstand Replacement, Rear Panel: step 1, image 1 of 1
      • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
      • Gently pry up on the rear panel around the edges until it is loose.
      Ask FixBot
    2. HTC Thunderbolt Kickstand Replacement: step 2, image 1 of 1
      • Lift and remove the rear panel.
      Ask FixBot
    1. HTC Thunderbolt Kickstand Replacement, Battery: step 3, image 1 of 2 HTC Thunderbolt Kickstand Replacement, Battery: step 3, image 2 of 2
      • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
      • Remove the battery from the inner frame.
      Ask FixBot
    1. HTC Thunderbolt Kickstand Replacement, MicroSD Card: step 4, image 1 of 2 HTC Thunderbolt Kickstand Replacement, MicroSD Card: step 4, image 2 of 2
      • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
      Ask FixBot
    2. HTC Thunderbolt Kickstand Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
      Ask FixBot
    1. HTC Thunderbolt Kickstand Replacement, Rear Frame: step 6, image 1 of 1
      • Remove the six Phillips screws from the perimeter of the rear frame.
      • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
      Ask FixBot
    2. HTC Thunderbolt Kickstand Replacement: step 7, image 1 of 2 HTC Thunderbolt Kickstand Replacement: step 7, image 2 of 2
      • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
      • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
      • Remove the plastic cover.
      • The plastic cover will have adhesive on it making it difficult to remove.
      Ask FixBot
    3. HTC Thunderbolt Kickstand Replacement: step 8, image 1 of 1
      • Remove the two Phillips screws where the plastic cover was.
      Ask FixBot
    4. HTC Thunderbolt Kickstand Replacement: step 9, image 1 of 2 HTC Thunderbolt Kickstand Replacement: step 9, image 2 of 2
      • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
      • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
      • Do the same for the opposite side of the phone.
      Ask FixBot
    5. HTC Thunderbolt Kickstand Replacement: step 10, image 1 of 3 HTC Thunderbolt Kickstand Replacement: step 10, image 2 of 3 HTC Thunderbolt Kickstand Replacement: step 10, image 3 of 3
      • Carefully separate the screen and phone from the rear frame, starting from the bottom.
      • Gently pull down on the phone and screen to fully separate it from the rear frame.
      Ask FixBot
    1. HTC Thunderbolt Kickstand Replacement, Kickstand: step 11, image 1 of 1
      • Remove the two Phillips screws on the bottom right of the rear frame.
      Ask FixBot
    2. HTC Thunderbolt Kickstand Replacement: step 12, image 1 of 1
      • Grab the kickstand and make sure it is fully extended.
      • Push the kickstand from the outside of the rear frame through the rear frame.
      Ask FixBot
Brandon Younger
212 Reputation
8 Guides authored
Cal Poly, Team 19-45, Regan Winter 2013 Member of Cal Poly, Team 19-45, Regan Winter 2013
CPSU-REGAN-W13S19G45
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 96
All Time: 1,155
