Up to 20% off select tools
HTC Surround Sim Card Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
73
All Time:
718
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
    1. HTC Surround Sim Card Replacement, Back Case: step 1, image 1 of 2 HTC Surround Sim Card Replacement, Back Case: step 1, image 2 of 2
      • Remove the back cover of the device to access the internal components of the HTC 7 Surround.
      • To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
      Ask FixBot
    2. HTC Surround Sim Card Replacement: step 2, image 1 of 3 HTC Surround Sim Card Replacement: step 2, image 2 of 3 HTC Surround Sim Card Replacement: step 2, image 3 of 3
      • Using a Phillips #00 screwdriver, remove the screws as directed.
      Ask FixBot
    3. HTC Surround Sim Card Replacement: step 3, image 1 of 1
      • Separate the screen and back cover with the opening tool.
      Ask FixBot
    1. HTC Surround Sim Card Replacement, SD Card: step 4, image 1 of 3 HTC Surround Sim Card Replacement, SD Card: step 4, image 2 of 3 HTC Surround Sim Card Replacement, SD Card: step 4, image 3 of 3
      • Look at the bottom right hand corner of the device and remove the silver tape covering the SD card slot with your fingers.
      • Insert the plastic opening tool directly underneath the orange surface below the SIM card until its removed from the surface of the device.
      Ask FixBot
    2. HTC Surround Sim Card Replacement: step 5, image 1 of 2 HTC Surround Sim Card Replacement: step 5, image 2 of 2
      • To get to the attachment that the SD/SIM card is attached to; insert the plastic opening tool underneath the lower motherboard until it is removed from the bottom half of the device.
      • You will notice the SD/SIM card is attached to the lower motherboard by a yellow piece of tape. Remove the tape from the back of motherboard with your fingers.
      Ask FixBot
    1. HTC Surround Sim Card Replacement, Sim Card: step 6, image 1 of 1
      • The SIM card slot will come off the device with the SD card slot and is ready to replace.
      Ask FixBot
Author
with
Michael Ronning
389 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 73
All Time: 718
