Up to 20% off select tools
HTC Rhyme Volume Button Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
93
All Time:
799
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
    1. HTC Rhyme Volume Button  Replacement, Removing Back Cover: step 1, image 1 of 1
      • Slide the bottom back cover off of the phone.
      Ask FixBot
    2. HTC Rhyme Volume Button  Replacement: step 2, image 1 of 1
      • Locate the four screws on the plastic cover and unscrew them.
      Ask FixBot
    3. HTC Rhyme Volume Button  Replacement: step 3, image 1 of 1
      • Pry the sticker off from the sides.
      • You can use a metal spudger to do this.
      • Peel the sticker off with your hands.
      Ask FixBot
    4. HTC Rhyme Volume Button  Replacement, Remove the plastic cover: step 4, image 1 of 1
      • Remove the plastic cover using your hands.
      Ask FixBot
    5. HTC Rhyme Volume Button  Replacement: step 5, image 1 of 1
      • Remove the yellow ribbon.
      Ask FixBot
    6. HTC Rhyme Volume Button  Replacement: step 6, image 1 of 3 HTC Rhyme Volume Button  Replacement: step 6, image 2 of 3 HTC Rhyme Volume Button  Replacement: step 6, image 3 of 3
      • Lift up the blue flaps underneath the battery.
      • Lift up the black flap at the top of the phone.
      • Lift up the black flap at the bottom of the phone.
      Ask FixBot
    7. HTC Rhyme Volume Button  Replacement, Remove the Motherboard: step 7, image 1 of 2 HTC Rhyme Volume Button  Replacement, Remove the Motherboard: step 7, image 2 of 2
      • Remove all 4 screws.
      • Carefully remove the motherboard with your hands.
      Ask FixBot
    8. HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: step 8, image 1 of 3 HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: step 8, image 2 of 3 HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: step 8, image 3 of 3
      • Pry the back plastic casing off with your hands.
      Ask FixBot
    9. HTC Rhyme Volume Button  Replacement: step 9, image 1 of 2 HTC Rhyme Volume Button  Replacement: step 9, image 2 of 2
      • Use the tip of a screwdriver to push the button out of the panel.
      Ask FixBot
Author
with
Frederick
119 Reputation
1 Guide authored
USF Tampa, Team 9-6, Leahy Fall 2014 Member of USF Tampa, Team 9-6, Leahy Fall 2014
USFT-LEAHY-F14S9G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 93
All Time: 799
