HTC Rhyme Speaker Replacement
    1. HTC Rhyme Speaker Replacement, Speaker: step 1, image 1 of 2 HTC Rhyme Speaker Replacement, Speaker: step 1, image 2 of 2
      • Slide the bottom back casing off, pulling down.
      Ask FixBot
    2. HTC Rhyme Speaker Replacement: step 2, image 1 of 2 HTC Rhyme Speaker Replacement: step 2, image 2 of 2
      • Using the plastic tool, pry underneath the top plastic cover.
      Ask FixBot
    3. HTC Rhyme Speaker Replacement: step 3, image 1 of 2 HTC Rhyme Speaker Replacement: step 3, image 2 of 2
      • Using a metal spudger, pry up the plastic piece covering the motherboard, and remove the sticker.
      Ask FixBot
    4. HTC Rhyme Speaker Replacement, Removing the Back Plastic Motherboard Cover: step 4, image 1 of 2 HTC Rhyme Speaker Replacement, Removing the Back Plastic Motherboard Cover: step 4, image 2 of 2
      • Use a Philip #0 screwdriver to remove the four screws of the plastic covering the motherboard.
      Ask FixBot
    5. HTC Rhyme Speaker Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers, remove the yellow ribbon by gently pulling on it.
      Ask FixBot
    6. HTC Rhyme Speaker Replacement: step 6, image 1 of 2 HTC Rhyme Speaker Replacement: step 6, image 2 of 2
      • Using the plastic tweezers, gently lift the blue flaps up.
      Ask FixBot
    7. HTC Rhyme Speaker Replacement: step 7, image 1 of 2 HTC Rhyme Speaker Replacement: step 7, image 2 of 2
      • Using your thumb, push the flap up on the top.
      • Using your thumb, push the flap up on the bottom of the motherboard.
      Ask FixBot
    8. HTC Rhyme Speaker Replacement, Unscrewing the Motherboard: step 8, image 1 of 2 HTC Rhyme Speaker Replacement, Unscrewing the Motherboard: step 8, image 2 of 2
      • Using a Phillips #00 screwdriver, unscrew the four screws in each corner of the motherboard.
      Ask FixBot
    9. HTC Rhyme Speaker Replacement, Removing the Motherboard: step 9, image 1 of 1
      • Carefully remove the motherboard from the base of the phone.
      Ask FixBot
    10. HTC Rhyme Speaker Replacement: step 10, image 1 of 3 HTC Rhyme Speaker Replacement: step 10, image 2 of 3 HTC Rhyme Speaker Replacement: step 10, image 3 of 3
      • Gently push the base of the phone from the frame.
      Ask FixBot
    11. HTC Rhyme Speaker Replacement, Battery Removal: step 11, image 1 of 2 HTC Rhyme Speaker Replacement, Battery Removal: step 11, image 2 of 2
      • Using the metal spudger, remove the battery from the base.
      Ask FixBot
    12. HTC Rhyme Speaker Replacement, Locating and Replacing the Speaker: step 12, image 1 of 2 HTC Rhyme Speaker Replacement, Locating and Replacing the Speaker: step 12, image 2 of 2
      • Using tweezers, lift the secondary motherboard from the base of the phone.
      • The speaker is located on the back of the board.
      Ask FixBot
Kelsey Harris
157 Reputation
1 Guide authored
USF Tampa, Team 9-6, Leahy Fall 2014 Member of USF Tampa, Team 9-6, Leahy Fall 2014
USFT-LEAHY-F14S9G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 108
All Time: 718
