HTC Rezound Vibration Monitor Replacement
    1. HTC Rezound Vibration Monitor Replacement, Battery: step 1, image 1 of 1
      • Use a plastic opening tool or your fingers to get into the groove between the cover and case. Remove the back covering so that the red battery is visible.
      Ask FixBot
    2. HTC Rezound Vibration Monitor Replacement: step 2, image 1 of 1
      • Remove the red battery to replace.
      Ask FixBot
    1. HTC Rezound Vibration Monitor Replacement, Vibration Monitor: step 3, image 1 of 3 HTC Rezound Vibration Monitor Replacement, Vibration Monitor: step 3, image 2 of 3 HTC Rezound Vibration Monitor Replacement, Vibration Monitor: step 3, image 3 of 3
      • Using a Torx T4 screwdriver, remove the six screws from the six spots shown in the photo.
      • Use a spudger to pry the casing from the phone.
      Ask FixBot
    2. HTC Rezound Vibration Monitor Replacement: step 4, image 1 of 2 HTC Rezound Vibration Monitor Replacement: step 4, image 2 of 2
      • Gently remove casing from phone.
      Ask FixBot
    3. HTC Rezound Vibration Monitor Replacement: step 5, image 1 of 1
      • Shown here is the vibration Monitor, this is what you will be replacing.
      Ask FixBot
    4. HTC Rezound Vibration Monitor Replacement: step 6, image 1 of 3 HTC Rezound Vibration Monitor Replacement: step 6, image 2 of 3 HTC Rezound Vibration Monitor Replacement: step 6, image 3 of 3
      • Remove the body of the monitor from the case attaching it to the motherboard.
      • Make sure to remove any potential obstruction that could be blocking the weight at the end!
      Ask FixBot
    5. HTC Rezound Vibration Monitor Replacement: step 7, image 1 of 1
      • Carefully disconnect the cable attached at the motherboard.
      Ask FixBot
    6. HTC Rezound Vibration Monitor Replacement: step 8, image 1 of 1
      • Insert the replacement's cable into the same spot on the logic board! Then just set it back into the slot on the logic board and you are done!
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 65
All Time: 529
