Up to 20% off select tools
HTC Rezound Front Camera Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
11
Past 30 Days:
61
All Time:
629
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
This guide is intended to help you remove and replace the forward facing camera on the HTC Rezound.
    1. HTC Rezound Front Camera Replacement, Battery: step 1, image 1 of 1
      • Use a plastic opening tool or your fingers to get into the groove between the cover and case. Remove the back covering so that the red battery is visible.
      Ask FixBot
    2. HTC Rezound Front Camera Replacement: step 2, image 1 of 1
      • Remove the red battery to replace.
      Ask FixBot
    1. HTC Rezound Front Camera Replacement, Screen: step 3, image 1 of 3 HTC Rezound Front Camera Replacement, Screen: step 3, image 2 of 3 HTC Rezound Front Camera Replacement, Screen: step 3, image 3 of 3
      • Unscrew the six screws (Torx T4 size) shown in the photo.
      • Use the spudger to pry the casing off of the phone.
      Ask FixBot
    2. HTC Rezound Front Camera Replacement: step 4, image 1 of 2 HTC Rezound Front Camera Replacement: step 4, image 2 of 2
      • Gently remove the casing from the phone.
      Ask FixBot
    3. HTC Rezound Front Camera Replacement: step 5, image 1 of 1
      • After the red casing is removed, the following components should be visible:
      • Main Camera
      • Headphone Jack
      • Vibration moter
      Ask FixBot
    4. HTC Rezound Front Camera Replacement: step 6, image 1 of 2 HTC Rezound Front Camera Replacement: step 6, image 2 of 2
      • Remove the 2 screws (Torx T7 size), which are located on the upper left and lower right sides of the device.
      Ask FixBot
    5. HTC Rezound Front Camera Replacement: step 7, image 1 of 3 HTC Rezound Front Camera Replacement: step 7, image 2 of 3 HTC Rezound Front Camera Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Using tweezers, flip the latch on the ribbon cables connecting the logic board to the screen and display. The screen and display for the HTC Rezound are likely fused to one another, so if you are replacing one you will likely need to replace both of them.
      • At this point all that's left is to insert the ribbon cables of your replacement into the same slot on the motherboard!
      Ask FixBot
    1. HTC Rezound Front Camera Replacement, Front Camera: step 8, image 1 of 1
      • Shown here is the camera that you will be replacing today!
      Ask FixBot
    2. HTC Rezound Front Camera Replacement: step 9, image 1 of 2 HTC Rezound Front Camera Replacement: step 9, image 2 of 2
      • Carefully flip the latch for the ribbon cable that connects the camera to the logic board.
      • Firmly grasp the cable, without crimping it, and slid it out of the slot.
      Ask FixBot
    3. HTC Rezound Front Camera Replacement: step 10, image 1 of 2 HTC Rezound Front Camera Replacement: step 10, image 2 of 2
      • Take the replacement camera and start to line it up with the slot in the logic board.
      • Fix ribbon cable to the slot and turn the latch back down to lock in place.
      Ask FixBot
Author
with
Evan Swartz
181 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 61
All Time: 629
