HTC Radar 4G Touch Digitizer Replacement
    1. HTC Radar 4G Touch Digitizer Replacement, Touch Digitizer: step 1, image 1 of 2 HTC Radar 4G Touch Digitizer Replacement, Touch Digitizer: step 1, image 2 of 2
      • Slide the lower plastic panel off of the phone.
      • Remove the four screws from the white plastic cover of the phone using the T5 Torx screwdriver.
      • Remove the two black screws from the silver frame.
      Ask FixBot
    2. HTC Radar 4G Touch Digitizer Replacement: step 2, image 1 of 1
      • Remove the back cover by pressing on the back of the motherboard lightly and pulling the screen out carefully.
      Ask FixBot
    3. HTC Radar 4G Touch Digitizer Replacement: step 3, image 1 of 1
      • Remove the battery from the phone using a fingernail or an opening pick.
      Ask FixBot
    4. HTC Radar 4G Touch Digitizer Replacement: step 4, image 1 of 1
      • Remove the three screws using a screwdriver.
      • Remove the plastic frame.
      Ask FixBot
    5. HTC Radar 4G Touch Digitizer Replacement: step 5, image 1 of 3 HTC Radar 4G Touch Digitizer Replacement: step 5, image 2 of 3 HTC Radar 4G Touch Digitizer Replacement: step 5, image 3 of 3
      • Remove the upper board and motherboard from the phone using an opening tool.
      • The regular black nylon spudger should be used whenever possible, especially around motherboards.
      Ask FixBot
    6. HTC Radar 4G Touch Digitizer Replacement: step 6, image 1 of 2 HTC Radar 4G Touch Digitizer Replacement: step 6, image 2 of 2
      • Use your hands to remove the touch digitizer.
      Ask FixBot
Kevin Guerra
101 Reputation
1 Guide authored
Texas Tech, Team 12-5, Bennett Fall 2016 Member of Texas Tech, Team 12-5, Bennett Fall 2016
TTU-BENNETT-F16S12G5
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 583
