HTC Radar 4G Battery Replacement
    1. HTC Radar 4G Battery Replacement, Slide off the back panel: step 1, image 1 of 2 HTC Radar 4G Battery Replacement, Slide off the back panel: step 1, image 2 of 2
      • Slide off the white back panel.
      • This is the time to remove the SIM card, so remove it now.
      Ask FixBot
    2. HTC Radar 4G Battery Replacement, Remove the motherboard protector screws: step 2, image 1 of 1
      • Remove the 4 silver T5 Torx screws from the motherboard protector.
      • Some screws may be stuck in. If so, use a pair of tweezers to carefully remove them from their holes.
      Ask FixBot
    3. HTC Radar 4G Battery Replacement, Slide off the rear motherboard protector: step 3, image 1 of 1
      • Carefully slide off the motherboard protector.
      • This may take some force if this is the first time opening the phone.
      • Take care not to apply too much downward force, because you may accidentally damage the sensitive components on the motherboard.
      Ask FixBot
    4. HTC Radar 4G Battery Replacement, Remove the frame screws: step 4, image 1 of 1
      • Remove the 2 black T5 Torx screws from the silver frame.
      • Make sure to not accidentally slip the screwdriver, because you may break sensitive components on the motherboard.
      Ask FixBot
    5. HTC Radar 4G Battery Replacement, Remove the casing: step 5, image 1 of 1
      • Gently push on the motherboard until the display starts to come out of its frame.
      • Once it is at about a 30-degree angle, grab the display and pull it downwards to remove it from the frame.
      • Remember, do this carefully. We don't want to end up with a dead motherboard.
      Ask FixBot
    1. HTC Radar 4G Battery Replacement, Remove the battery: step 6, image 1 of 1
      Tool used on this step:
      iFixit Opening Picks (Set of 6)
      $4.95
      Buy
      • Use a fingernail or an opening pick to lift the battery out of its slot.
      • Insert the opening pick on the right side at the top for best results.
      • Once it is at about a 30-degree angle, pull up on the battery to disconnect it.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Calibrate your new battery for optimal performance.Take your e-waste to an R2 or e-Stewards certified recycler.
hellonearth311
390 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 31
All Time: 391
