Up to 20% off select tools
HTC Ozone LCD Display Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
88
All Time:
2,796
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
    1. HTC Ozone LCD Display Replacement, Rear Battery Cover: step 1, image 1 of 1
      • Flip the phone over to have the rear cover facing up.
      • The camera lens should be towards the top of the phone.
      Ask FixBot
    2. HTC Ozone LCD Display Replacement: step 2, image 1 of 2 HTC Ozone LCD Display Replacement: step 2, image 2 of 2
      • Slide the cover up, towards the top of phone, to unlock the battery cover.
      • Lift the cover off phone and remove it.
      Ask FixBot
    1. HTC Ozone LCD Display Replacement, Battery: step 3, image 1 of 3 HTC Ozone LCD Display Replacement, Battery: step 3, image 2 of 3 HTC Ozone LCD Display Replacement, Battery: step 3, image 3 of 3
      • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
      Ask FixBot
    1. HTC Ozone LCD Display Replacement, Frame: step 4, image 1 of 2 HTC Ozone LCD Display Replacement, Frame: step 4, image 2 of 2
      • Remove the six Torx #5 screws that are securing the rear frame.
      Ask FixBot
    2. HTC Ozone LCD Display Replacement: step 5, image 1 of 3 HTC Ozone LCD Display Replacement: step 5, image 2 of 3 HTC Ozone LCD Display Replacement: step 5, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
      • A plastic card can be used instead of the plastic opening tool.
      Ask FixBot
    1. HTC Ozone LCD Display Replacement, Motherboard: step 6, image 1 of 2 HTC Ozone LCD Display Replacement, Motherboard: step 6, image 2 of 2
      • Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
      Ask FixBot
    2. HTC Ozone LCD Display Replacement: step 7, image 1 of 2 HTC Ozone LCD Display Replacement: step 7, image 2 of 2
      • Pry the motherboard away from the front of the plastic case using a plastic opening tool.
      • Be careful not to break the ribbon cable when prying away the motherboard.
      Ask FixBot
    3. HTC Ozone LCD Display Replacement: step 8, image 1 of 3 HTC Ozone LCD Display Replacement: step 8, image 2 of 3 HTC Ozone LCD Display Replacement: step 8, image 3 of 3
      • Remove the plastic cover from the LCD display and the motherboard.
      • The Motherboard and the LCD are still attached together.
      Ask FixBot
    1. HTC Ozone LCD Display Replacement, LCD Display: step 9, image 1 of 2 HTC Ozone LCD Display Replacement, LCD Display: step 9, image 2 of 2
      • Remove the gray tape securing the ribbon cable.
      Ask FixBot
    2. HTC Ozone LCD Display Replacement: step 10, image 1 of 1
      • Remove the yellow tape securing the connector lock.
      Ask FixBot
    3. HTC Ozone LCD Display Replacement: step 11, image 1 of 2 HTC Ozone LCD Display Replacement: step 11, image 2 of 2
      • Carefully lift the black lock to release the ribbon cable, using the plastic opening tool.
      Ask FixBot
    4. HTC Ozone LCD Display Replacement: step 12, image 1 of 1
      • Pull the ribbon cable upwards, disconnecting it from the Motherboard.
      Ask FixBot
    5. HTC Ozone LCD Display Replacement: step 13, image 1 of 1
      • Lift the Motherboard away from the LCD display.
      Ask FixBot
2 other people completed this guide.
Author
with
Marco Jokada
247 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 88
All Time: 2,796
