Up to 20% off select tools
HTC Ozone Keyboard Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
89
All Time:
2,365
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
    1. HTC Ozone Keyboard Replacement, Rear Battery Cover: step 1, image 1 of 1
      • Flip the phone over to have the rear cover facing up.
      • The camera lens should be towards the top of the phone.
      Ask FixBot
    2. HTC Ozone Keyboard Replacement: step 2, image 1 of 2 HTC Ozone Keyboard Replacement: step 2, image 2 of 2
      • Slide the cover up, towards the top of phone, to unlock the battery cover.
      • Lift the cover off phone and remove it.
      Ask FixBot
    1. HTC Ozone Keyboard Replacement, Battery: step 3, image 1 of 3 HTC Ozone Keyboard Replacement, Battery: step 3, image 2 of 3 HTC Ozone Keyboard Replacement, Battery: step 3, image 3 of 3
      • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
      Ask FixBot
    1. HTC Ozone Keyboard Replacement, Frame: step 4, image 1 of 2 HTC Ozone Keyboard Replacement, Frame: step 4, image 2 of 2
      • Remove the six Torx #5 screws that are securing the rear frame.
      Ask FixBot
    2. HTC Ozone Keyboard Replacement: step 5, image 1 of 3 HTC Ozone Keyboard Replacement: step 5, image 2 of 3 HTC Ozone Keyboard Replacement: step 5, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
      • A plastic card can be used instead of the plastic opening tool.
      Ask FixBot
    1. HTC Ozone Keyboard Replacement, Motherboard: step 6, image 1 of 2 HTC Ozone Keyboard Replacement, Motherboard: step 6, image 2 of 2
      • Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
      Ask FixBot
    2. HTC Ozone Keyboard Replacement: step 7, image 1 of 2 HTC Ozone Keyboard Replacement: step 7, image 2 of 2
      • Pry the motherboard away from the front of the plastic case using a plastic opening tool.
      • Be careful not to break the ribbon cable when prying away the motherboard.
      Ask FixBot
    3. HTC Ozone Keyboard Replacement: step 8, image 1 of 3 HTC Ozone Keyboard Replacement: step 8, image 2 of 3 HTC Ozone Keyboard Replacement: step 8, image 3 of 3
      • Remove the plastic cover from the LCD display and the motherboard.
      • The Motherboard and the LCD are still attached together.
      Ask FixBot
    1. HTC Ozone Keyboard Replacement, LCD Display: step 9, image 1 of 2 HTC Ozone Keyboard Replacement, LCD Display: step 9, image 2 of 2
      • Remove the gray tape securing the ribbon cable.
      Ask FixBot
    2. HTC Ozone Keyboard Replacement: step 10, image 1 of 1
      • Remove the yellow tape securing the connector lock.
      Ask FixBot
    3. HTC Ozone Keyboard Replacement: step 11, image 1 of 2 HTC Ozone Keyboard Replacement: step 11, image 2 of 2
      • Carefully lift the black lock to release the ribbon cable, using the plastic opening tool.
      Ask FixBot
    4. HTC Ozone Keyboard Replacement: step 12, image 1 of 1
      • Pull the ribbon cable upwards, disconnecting it from the Motherboard.
      Ask FixBot
    5. HTC Ozone Keyboard Replacement: step 13, image 1 of 1
      • Lift the Motherboard away from the LCD display.
      Ask FixBot
    1. HTC Ozone Keyboard Replacement, Keyboard: step 14, image 1 of 2 HTC Ozone Keyboard Replacement, Keyboard: step 14, image 2 of 2
      • Lift off main keyboard from front plastic case using plastic opening tool.
      Ask FixBot
    2. HTC Ozone Keyboard Replacement: step 15, image 1 of 2 HTC Ozone Keyboard Replacement: step 15, image 2 of 2
      • Remove four Phillips #00 screws securing function keys.
      Ask FixBot
    3. HTC Ozone Keyboard Replacement: step 16, image 1 of 2 HTC Ozone Keyboard Replacement: step 16, image 2 of 2
      • Pop keys out by pushing keys from back of the phone.
      Ask FixBot
Author
with
Marco Jokada
247 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 89
All Time: 2,365
