HTC One X Plus Antenna Replacement
    1. HTC One X Plus Antenna Replacement, Antenna: step 1, image 1 of 1
      • Power off your device.
      • Insert a pin, paper clip, or very small piece of metal into the hole next to the micro-SIM card holder to remove it.
      • The SIM card slot is located on the top edge of the device.
      Ask FixBot
    2. HTC One X Plus Antenna Replacement: step 2, image 1 of 3 HTC One X Plus Antenna Replacement: step 2, image 2 of 3 HTC One X Plus Antenna Replacement: step 2, image 3 of 3
      • Using the plastic opening tools, pry open the bottom of the device first.
      • You will hear clicking sounds as the sides of the device detach from the screen.
      • Once both sides are detached, use the suction cup tool to remove the screen completely from the black encasing.
      Ask FixBot
    3. HTC One X Plus Antenna Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Now that the rear panel has been removed, use the metal tweezers to carefully remove the antenna.
      • The antenna is the loose black wire located to the right of the battery.
      • Using the metal tweezers, connect and install your new antenna, securing the antenna beneath the metal supports.
      Ask FixBot
2 other people completed this guide.
Jason Melo
483 Reputation
4 Guides authored
USF Tampa, Team 3-3, Eyestone Fall 2015 Member of USF Tampa, Team 3-3, Eyestone Fall 2015
USFT-EYESTONE-F15S3G3
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 56
All Time: 1,020
