Up to 20% off select tools
HTC One X Motherboard Replacement
Views: 10K
View statistics:
Past 24 Hours:
4
Past 7 Days:
26
Past 30 Days:
93
All Time:
10,207
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
As the HTC One X is not a very user-friendly phone to repair, this guide will take you through the specific steps to disassemble your phone and will branch off into a specific repair guide for whatever problem you're experiencing.
    1. HTC One X Motherboard Replacement, Remove SIM card slot: step 1, image 1 of 1
      • Insert a safety pin, or other small object in the small opening next to the Sim card slot to remove the SIM card.
      • The Sim Card Slot is located at the top of the rear panel.
      Ask FixBot
    2. HTC One X Motherboard Replacement, Remove front panel: step 2, image 1 of 2 HTC One X Motherboard Replacement, Remove front panel: step 2, image 2 of 2
      • Using a plastic opening tool, carefully separate the display screen from the rear panel.
      • The display assembly is a tight fit therefore the removal must be carried out carefully with firm, constant force being applied around the bottom corners and sides of the panel. Note that the top of the phone is underneath the panel, and will not come out.
      • If your display is cracked, take extra caution when separating the display from the rear panel to prevent further breakage.
      • Set aside the rear panel.
      Ask FixBot
    3. HTC One X Motherboard Replacement, Remove the top plastic panel: step 3, image 1 of 2 HTC One X Motherboard Replacement, Remove the top plastic panel: step 3, image 2 of 2
      • Remove the five screws at the top of the panel using a Phillips head screwdriver.
      • Two 2.05mm Philips head screws
      • Three 2.44mm Philips head screws
      • Also remove the screws with the warranty stickers.
      • Once the screws are removed, gently remove the plastic cover using a plastic opening tool to detach the edges from the front panel.
      • Once you have disassembled your device, your warranty will no longer be valid.
      Ask FixBot
    4. HTC One X Motherboard Replacement, Remove antenna and disconnect the PCB board: step 4, image 1 of 2 HTC One X Motherboard Replacement, Remove antenna and disconnect the PCB board: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the two screws at the bottom right corner of the front panel using a Phillips head screwdriver, as shown in the image.
      • Two 3.35mm Philips head screws
      • Use tweezers to disconnect the antenna from the logic board to the PCB board.
      • Remove the tape connected to the motherboard.
      Ask FixBot
    5. HTC One X Motherboard Replacement, Disconnect the battery and remove PCB board: step 5, image 1 of 3 HTC One X Motherboard Replacement, Disconnect the battery and remove PCB board: step 5, image 2 of 3 HTC One X Motherboard Replacement, Disconnect the battery and remove PCB board: step 5, image 3 of 3
      • Remove the tape holding the battery in place.
      • Gently lift the battery from the bottom using a plastic opening tool.
      • You may have to apply heat to melt the glue holding the battery in place.
      • Do not completely remove the battery yet
      • You can now disconnect the flex cable holding the PCB board place. Gently open the gates using tweezers or a plastic opening tool and use tweezers to slide the flex cable out.
      • Now that it's separated, remove and set aside the PCB board.
      Ask FixBot
    6. HTC One X Motherboard Replacement, Disconnect flex cables: step 6, image 1 of 3 HTC One X Motherboard Replacement, Disconnect flex cables: step 6, image 2 of 3 HTC One X Motherboard Replacement, Disconnect flex cables: step 6, image 3 of 3
      • Place the battery back into its original position once the PCB board has been removed
      • Use tweezers to disconnect the power button flex cables.
      • Disconnect the volume flex cable by opening the gate and then sliding the cable out using tweezers.
      • Disconnect the touchscreen flex cable
      • If repairing hard buttons, skip step 7.
      Ask FixBot
    7. HTC One X Motherboard Replacement, Remove logic board: step 7, image 1 of 1
      • Disconnect the remaining two flex cables in a similar manner before completely removing the logic board.
      • You may now remove the board safely
      Ask FixBot
5 other people completed this guide.
Author
with
Blain Abebe
769 Reputation
3 Guides authored
USF Tampa, Team 4-3, Brown Fall 2014 Member of USF Tampa, Team 4-3, Brown Fall 2014
USFT-BROWN-F14S4G3
3 Members
84 Guides authored
1 Guide Comment
can we replace the mother board of htc one x with the one of htc one x + ??????
elmarconi75 - Reply Share
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 93
All Time: 10,207
