HTC One V Loudspeaker Replacement
    1. HTC One V Loudspeaker Replacement, Disassembling HTC ONE V Bottom Assembly: step 1, image 1 of 3 HTC One V Loudspeaker Replacement, Disassembling HTC ONE V Bottom Assembly: step 1, image 2 of 3 HTC One V Loudspeaker Replacement, Disassembling HTC ONE V Bottom Assembly: step 1, image 3 of 3
      • Power off your device.
      • Remove the bottom cover by sliding it off.
      Ask FixBot
    2. HTC One V Loudspeaker Replacement: step 2, image 1 of 1
      • Remove the SIM card.
      • Remove the four screws securing the bottom casing.
      • Two 3.0 mm Phillips #0 screws in the top left and right corners.
      • Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
      Ask FixBot
    3. HTC One V Loudspeaker Replacement: step 3, image 1 of 2 HTC One V Loudspeaker Replacement: step 3, image 2 of 2
      • Remove the 2.0 mm Phillips #0 screws on either side of the phone.
      Ask FixBot
    4. HTC One V Loudspeaker Replacement: step 4, image 1 of 3 HTC One V Loudspeaker Replacement: step 4, image 2 of 3 HTC One V Loudspeaker Replacement: step 4, image 3 of 3
      • Use a plastic opening tool to pry open the bottom casing.
      • Remove the bottom casing by pulling it towards you.
      Ask FixBot
    1. HTC One V Loudspeaker Replacement, Loudspeaker: step 5, image 1 of 2 HTC One V Loudspeaker Replacement, Loudspeaker: step 5, image 2 of 2
      • Using a plastic opening tool, peel off the speaker cover.
      Ask FixBot
    2. HTC One V Loudspeaker Replacement: step 6, image 1 of 1
      • Use the spudger to push the speaker out of its casing.
      Ask FixBot
abebe alemu
101 Reputation
1 Guide authored
USF Tampa, Team 1-3, Blackwell Winter 2015 Member of USF Tampa, Team 1-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G3
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 102
All Time: 874
