Up to 20% off select tools
HTC One V Camera Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
91
All Time:
1,571
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
If your phone is taking distorted pictures or your pictures appear with lines, a cracked or faulty camera could be to blame.
    1. HTC One V Camera Replacement, Disassembling HTC ONE V Bottom Assembly: step 1, image 1 of 3 HTC One V Camera Replacement, Disassembling HTC ONE V Bottom Assembly: step 1, image 2 of 3 HTC One V Camera Replacement, Disassembling HTC ONE V Bottom Assembly: step 1, image 3 of 3
      • Power off your device.
      • Remove the bottom cover by sliding it off.
      Ask FixBot
    2. HTC One V Camera Replacement: step 2, image 1 of 1
      • Remove the SIM card.
      • Remove the four screws securing the bottom casing.
      • Two 3.0 mm Phillips #0 screws in the top left and right corners.
      • Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
      Ask FixBot
    3. HTC One V Camera Replacement: step 3, image 1 of 2 HTC One V Camera Replacement: step 3, image 2 of 2
      • Remove the 2.0 mm Phillips #0 screws on either side of the phone.
      Ask FixBot
    4. HTC One V Camera Replacement: step 4, image 1 of 3 HTC One V Camera Replacement: step 4, image 2 of 3 HTC One V Camera Replacement: step 4, image 3 of 3
      • Use a plastic opening tool to pry open the bottom casing.
      • Remove the bottom casing by pulling it towards you.
      Ask FixBot
    1. HTC One V Camera Replacement, Disassembling HTC One V Back Case: step 5, image 1 of 3 HTC One V Camera Replacement, Disassembling HTC One V Back Case: step 5, image 2 of 3 HTC One V Camera Replacement, Disassembling HTC One V Back Case: step 5, image 3 of 3
      • Use the plastic opening tool to pry open the rear camera panel.
      • Remove both screws that are securing the back case.
      • One 4.0 mm Phillips #0 screw.
      • One 3.0 mm Phillips #0 screw.
      Ask FixBot
    2. HTC One V Camera Replacement: step 6, image 1 of 3 HTC One V Camera Replacement: step 6, image 2 of 3 HTC One V Camera Replacement: step 6, image 3 of 3
      • Use a Jimmy to pry up the OEM SIM and SD card reader contact.
      • Pry from right to left to avoid potential damages to the ribbon.
      Ask FixBot
    3. HTC One V Camera Replacement: step 7, image 1 of 3 HTC One V Camera Replacement: step 7, image 2 of 3 HTC One V Camera Replacement: step 7, image 3 of 3
      • Using both thumbs, gently push on the two bottom rear corners of the motherboard.
      • Gently and slowly pull the screen out from the front of the phone, while feeding the OEM reader contact through the opening.
      Ask FixBot
    1. HTC One V Camera Replacement, Battery: step 8, image 1 of 1
      • Pry up the battery with the flat end of the spudger.
      Ask FixBot
    2. HTC One V Camera Replacement: step 9, image 1 of 3 HTC One V Camera Replacement: step 9, image 2 of 3 HTC One V Camera Replacement: step 9, image 3 of 3
      • Gently lift up the battery away from the edge of its housing.
      • Use the point end of the spudger to push the connection out of its housing.
      Ask FixBot
    1. HTC One V Camera Replacement, Camera Lens: step 10, image 1 of 3 HTC One V Camera Replacement, Camera Lens: step 10, image 2 of 3 HTC One V Camera Replacement, Camera Lens: step 10, image 3 of 3
      • Remove the two 3.0 mm Phillips #0 screws, that are securing the camera lens.
      Ask FixBot
    2. HTC One V Camera Replacement: step 11, image 1 of 1
      • Pry off the camera lens using a plastic opening tool.
      Ask FixBot
    3. HTC One V Camera Replacement, Vibrator: step 12, image 1 of 2 HTC One V Camera Replacement, Vibrator: step 12, image 2 of 2
      Tool used on this step:
      Buy
      • Pry the vibrator out of the housing with a spudger.
      • Using the tweezers, pull up on the connecting wires detaching the vibrator from the motherboard.
      Ask FixBot
    1. HTC One V Camera Replacement, Motherboard: step 13, image 1 of 3 HTC One V Camera Replacement, Motherboard: step 13, image 2 of 3 HTC One V Camera Replacement, Motherboard: step 13, image 3 of 3
      • Using the spudger lift the tabs on the highlighted, red and orange, ribbon connectors. Gently pull out the ribbons from their connectors.
      • Remove the 3.0 mm Phillips #0 screw.
      Ask FixBot
    2. HTC One V Camera Replacement: step 14, image 1 of 3 HTC One V Camera Replacement: step 14, image 2 of 3 HTC One V Camera Replacement: step 14, image 3 of 3
      Buy
      • Using tweezers, pull back on the tape located on the bottom corners of the motherboard.
      Ask FixBot
    3. HTC One V Camera Replacement: step 15, image 1 of 2 HTC One V Camera Replacement: step 15, image 2 of 2
      • Use the spudger to push back the latch holding on the motherboard. While the latch is pushed back use the plastic opening tool to pry up the motherboard.
      Ask FixBot
    4. HTC One V Camera Replacement: step 16, image 1 of 1
      • Place your phone on its side so that you can gently pull up on the motherboard to expose its last connector.
      • Using the flat end of the spudger, pop of the connector.
      Ask FixBot
    1. HTC One V Camera Replacement, Camera: step 17, image 1 of 2 HTC One V Camera Replacement, Camera: step 17, image 2 of 2
      • Flip motherboard over so the backside is up.
      Ask FixBot
    2. HTC One V Camera Replacement: step 18, image 1 of 2 HTC One V Camera Replacement: step 18, image 2 of 2
      Buy
      • Pull the camera back using the tweezers, and hold it.
      • Use the spudger to unlock the camera's ribbon from its connector.
      • Using the tweezers, pull up on the ribbon and release the camera form the motherboard.
      • The ribbon is connected to the back of the LCD display by tape. Slowly pull the ribbon back and the tape will follow.
      Ask FixBot
2 other people completed this guide.
Author
with
Michael Lucido
852 Reputation
6 Guides authored
USF Tampa, Team 1-3, Blackwell Winter 2015 Member of USF Tampa, Team 1-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G3
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 91
All Time: 1,571
