Tools
Spudger4.9
Introduction
Go to step 1 ↓If your phone will not hold a charge very long or even turn on, a faulty battery might be the problem. A new one can be installed using this guide.
Power off your device.
Remove the bottom cover by sliding it off.
Use the plastic opening tool to pry open the rear camera panel.
Remove both screws that are securing the back case.
One 4.0 mm Phillips #0 screw.
One 3.0 mm Phillips #0 screw.
9 other people completed this guide.
5 Guide Comments
Good guide! At step 6 it was easier for me to start pry from felt to right. I'm not sure, but it seems there is 2 ribbons not one, and it maybe I accidentally teared the one on the right. I really not sure, because my speaker still working. Take care! A closer image from the ribbon(s) would help!
Thank you, my phone is working again!
Step 6 was difficult because the card reader contact was stuck down with some kind of adhesive
In Step 4, a small rubber block fell out and it took a while to work out where it belongs. You can just make out where it should be in the bottom left of the second photo in Step 4.
Overall, great instructions, and thank you!
Very well -understood process! Excellent!
