Up to 20% off select tools
HTC One Speaker Replacement
Views: 20K
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
104
All Time:
20,494
Comments: 2
2 guide comments.
Go to guide comments
Completed: 16
16 people have marked this guide "completed." Will you be next?
Favorites: 18
18 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 hours
Difficulty: Very difficult
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
If you have an issue with your speaker as stated in our troubleshooting page ( HTC One M7 Troubleshooting ) then this guide is for you.
    1. HTC One Speaker Replacement, Speaker: step 1, image 1 of 3 HTC One Speaker Replacement, Speaker: step 1, image 2 of 3 HTC One Speaker Replacement, Speaker: step 1, image 3 of 3
      • Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel.
      Ask FixBot
    2. HTC One Speaker Replacement: step 2, image 1 of 1
      • Pry the back loose and lift. The back panel will come off with time.
      Ask FixBot
    3. HTC One Speaker Replacement: step 3, image 1 of 1
      • Remove all of the screw which are located on the backside of the phone with a #000 Phillip screw driver.
      • Remove the tape gently to find some hidden screws underneath.
      Ask FixBot
    4. HTC One Speaker Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to get underneath the motherboard to lift.
      • Lift gently because the motherboard is not completely disconnected.
      Ask FixBot
    5. HTC One Speaker Replacement: step 5, image 1 of 1
      • Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it)
      • Lift the camera from the bottom of the motherboard.
      Ask FixBot
    6. HTC One Speaker Replacement: step 6, image 1 of 2 HTC One Speaker Replacement: step 6, image 2 of 2
      • Remove the motherboard completely out of the phone.
      • May stay attached from one end by tape.
      Ask FixBot
    7. HTC One Speaker Replacement: step 7, image 1 of 2 HTC One Speaker Replacement: step 7, image 2 of 2
      • Use the blue opening tool to pry the battery from the frame.
      • Some force will be needed since the battery is glued to the frame.
      • Be careful to not break the battery upon removal.
      Ask FixBot
    8. HTC One Speaker Replacement: step 8, image 1 of 3 HTC One Speaker Replacement: step 8, image 2 of 3 HTC One Speaker Replacement: step 8, image 3 of 3
      • Completely remove the motherboard.
      Ask FixBot
    9. HTC One Speaker Replacement: step 9, image 1 of 2 HTC One Speaker Replacement: step 9, image 2 of 2
      • Remove the #000 screws around the speaker that are located at the bottom of the frame.
      • Lift the speaker out of the frame.
      Ask FixBot
16 other people completed this guide.
Author
with
Alex
664 Reputation
1 Guide authored
USF Tampa, Team 12-1, Blackwell Fall 2014 Member of USF Tampa, Team 12-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G1
4 Members
60 Guides authored
2 Guide Comments
Ok I will good
Raguraman - Reply Share
Where to buy speaker???
bharatdshmkh - Reply Share
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 104
All Time: 20,494
