Up to 20% off select tools
HTC One Remix Battery Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
59
All Time:
1,150
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 35 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will take you through the process of replacing the battery in an HTC One Remix.
    1. HTC One Remix Battery Replacement, Battery: step 1, image 1 of 1
      • Use the sim eject tool to remove the SIM cards on either side of the phone.
      Ask FixBot
    2. HTC One Remix Battery Replacement: step 2, image 1 of 1
      Ask FixBot
    3. HTC One Remix Battery Replacement: step 3, image 1 of 1
      • Once the top of the phone is warm, use a plastic spudger to pry up the left corner and pull it off.
      • The top is glued on so it may be difficult to pull off.
      Ask FixBot
    4. HTC One Remix Battery Replacement: step 4, image 1 of 1
      • Take out the single 3mm screw that is on the top left side using a Torx 4 screwdriver.
      Ask FixBot
    5. HTC One Remix Battery Replacement: step 5, image 1 of 2 HTC One Remix Battery Replacement: step 5, image 2 of 2
      • Use the plastic spudger to pry off the back cover. Place the tool in the SIM card insert and lift the back cover with force. Continue to do this all around the phone.
      • Be careful not to break the wiring that is connected from the inside of the phone to the back of the phone.
      Ask FixBot
    6. HTC One Remix Battery Replacement: step 6, image 1 of 2 HTC One Remix Battery Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • With tweezers, remove the small pieces of yellow tape that cover the ZIF connectors.
      • Use the plastic prying tool to take off the three pieces of silver tape. They are located at the bottom right corner of the copper plate.
      Ask FixBot
    7. HTC One Remix Battery Replacement: step 7, image 1 of 3 HTC One Remix Battery Replacement: step 7, image 2 of 3 HTC One Remix Battery Replacement: step 7, image 3 of 3
      • With the plastic spudger, disconnect the eight ZIF connectors.
      • Use tweezers to carefully detach the eight ribbon cables from the ZIF connectors.
      Ask FixBot
    8. HTC One Remix Battery Replacement: step 8, image 1 of 1
      • Remove the two 1mm screws at the bottom right of the motherboard using a Phillips #00 screwdriver.
      Ask FixBot
    9. HTC One Remix Battery Replacement: step 9, image 1 of 3 HTC One Remix Battery Replacement: step 9, image 2 of 3 HTC One Remix Battery Replacement: step 9, image 3 of 3
      • Pull off one end of each of the five colored connecting cables from the motherboard.
      • Pull back the black and red wire on the motherboard on the bottom left.
      Ask FixBot
    10. HTC One Remix Battery Replacement: step 10, image 1 of 1
      • Take out the four 3mm screws that are on each corner of the motherboard using a Torx 4 screwdriver.
      • Gently lift the motherboard out of the phone using the plastic spudger.
      • Make sure the ribbon cables are out of the way when removing the motherboard.
      Ask FixBot
    11. HTC One Remix Battery Replacement: step 11, image 1 of 1
      • Pull back the ZIF and ribbon connectors and place the plastic opening tool into the indentation between the battery and the frame of the phone. Continue to do this around each side of the battery by gently prying.
      Ask FixBot
    12. HTC One Remix Battery Replacement: step 12, image 1 of 1
      • Gently pull the battery from the HTC One Remix.
      • This may be somewhat difficult due to the adhesive keeping the battery in place. Carefully pull and watch the orange tab at the bottom right of the battery. It may get stuck.
      Ask FixBot
Author
with
Marcos Loza
936 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 59
All Time: 1,150
