Up to 20% off select tools
HTC One Motherboard Replacement
Views: 16K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
112
All Time:
16,082
Comments: 2
2 guide comments.
Go to guide comments
Completed: 14
14 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. HTC One Motherboard Replacement, Front Panel: step 1, image 1 of 1
      • Use the plastic opening tool to loosen the adhesive from the crease surrounding the screen.
      • The volume button is a good place to begin, it should come right out as you pry.
      Ask FixBot
    2. HTC One Motherboard Replacement: step 2, image 1 of 1
      • Wedge the plastic opening tool into the crack around the screen, on only the top, left and right sides.
      • Applying heat with the iOpener or a heat gun can speed this process.
      Ask FixBot
    3. HTC One Motherboard Replacement: step 3, image 1 of 1
      • Once the screen has been loosened on the top, left and right edges, lift the screen. It will remain attached at the bottom on a hinge.
      • The screen will remain attached to this hinge until the final step.
      Ask FixBot
    4. HTC One Motherboard Replacement: step 4, image 1 of 1
      • Carefully remove the volume button. Loosen the back panel of the phone with the plastic opening tool. Begin loosening and prying in the space where the battery was.
      Ask FixBot
    5. HTC One Motherboard Replacement: step 5, image 1 of 1
      • Once the crease has been loosened all around, pry the back panel open and lift until it can be removed.
      Ask FixBot
    6. HTC One Motherboard Replacement: step 6, image 1 of 1
      • Remove tape to expose #000 screws, remove all screws.
      • Use the #000 bit screwdriver
      Ask FixBot
    7. HTC One Motherboard Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Reach beneath the motherboard with the tweezers, grip it and lift.
      • Lift with care, the motherboard is not completely disconnected yet.
      • Remove the tape connecting the motherboard to the phone and gently lift it out.
      Ask FixBot
14 other people completed this guide.
Author
with
Meghan
479 Reputation
1 Guide authored
USF Tampa, Team 12-1, Blackwell Fall 2014 Member of USF Tampa, Team 12-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G1
4 Members
60 Guides authored
2 Guide Comments
Where can I buy a motherboard to do the replacement?
Askateth - Reply Share
Will changing the motherboard fix the pink tint in my camera?
mmm50592 - Reply Share
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 112
All Time: 16,082
