Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓This repair guide will show you step-by-step how to take off the rear casing of your HTC One Mini and safely remove your current rear camera.
Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
Remove the lower speaker cover.
Tool used on this step:Tweezers$4.99
Use tweezers to remove the yellow tape covering the flex cable connectors (total of five).
Remove the motherboard and place it so that the rear camera is face down.
2 other people completed this guide.
