Up to 20% off select tools
HTC One Mini Motherboard Replacement
Views: 5.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
15
Past 30 Days:
96
All Time:
5,779
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
Follow the instructions in this guide to remove your HTC One Mini's rear case and detach your motherboard from the rest of the phone so that it may be replaced.
    1. HTC One Mini Motherboard Replacement, iOpener Heating: step 1, image 1 of 1
      • Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
      Ask FixBot
    2. HTC One Mini Motherboard Replacement, Remove Speaker Grills: step 2, image 1 of 1
      • Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
      • Remove the lower speaker cover.
      Ask FixBot
    3. HTC One Mini Motherboard Replacement, Remove Screw: step 3, image 1 of 3 HTC One Mini Motherboard Replacement, Remove Screw: step 3, image 2 of 3 HTC One Mini Motherboard Replacement, Remove Screw: step 3, image 3 of 3
      • Remove the screw under the speaker cover using a T6 Torx screwdriver.
      Ask FixBot
    4. HTC One Mini Motherboard Replacement: step 4, image 1 of 3 HTC One Mini Motherboard Replacement: step 4, image 2 of 3 HTC One Mini Motherboard Replacement: step 4, image 3 of 3
      • Slide a thin guitar pick or pry tool between the edge of the display and the rear case, near the bottom of the phone.
      • Carefully work your way up each side of the display and separate the rear case. There are three clips on each side.
      Ask FixBot
    5. HTC One Mini Motherboard Replacement, Separate Rear Case: step 5, image 1 of 2 HTC One Mini Motherboard Replacement, Separate Rear Case: step 5, image 2 of 2
      • Remove the rear case from the phone.
      Ask FixBot
    1. HTC One Mini Motherboard Replacement, Remove Screws: step 6, image 1 of 3 HTC One Mini Motherboard Replacement, Remove Screws: step 6, image 2 of 3 HTC One Mini Motherboard Replacement, Remove Screws: step 6, image 3 of 3
      • Remove the two Phillips screws securing the battery connector.
      Ask FixBot
    2. HTC One Mini Motherboard Replacement: step 7, image 1 of 2 HTC One Mini Motherboard Replacement: step 7, image 2 of 2
      • Disconnect the battery by prying the metal cover straight up.
      Ask FixBot
    3. HTC One Mini Motherboard Replacement, Remove screws: step 8, image 1 of 3 HTC One Mini Motherboard Replacement, Remove screws: step 8, image 2 of 3 HTC One Mini Motherboard Replacement, Remove screws: step 8, image 3 of 3
      • Remove two Phillips screws.
      • The screw on the upper right corner secures a tiny golden washer. Remove this washer.
      Ask FixBot
    4. HTC One Mini Motherboard Replacement, Remove Screws: step 9, image 1 of 3 HTC One Mini Motherboard Replacement, Remove Screws: step 9, image 2 of 3 HTC One Mini Motherboard Replacement, Remove Screws: step 9, image 3 of 3
      • Remove the two small black Phillips screws.
      Ask FixBot
    5. HTC One Mini Motherboard Replacement, Remove Screws: step 10, image 1 of 3 HTC One Mini Motherboard Replacement, Remove Screws: step 10, image 2 of 3 HTC One Mini Motherboard Replacement, Remove Screws: step 10, image 3 of 3
      • Remove two more Phillips screws.
      Ask FixBot
    6. HTC One Mini Motherboard Replacement, Remove protective foil.: step 11, image 1 of 3 HTC One Mini Motherboard Replacement, Remove protective foil.: step 11, image 2 of 3 HTC One Mini Motherboard Replacement, Remove protective foil.: step 11, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to remove the yellow tape covering the flex cable connectors (total of five).
      Ask FixBot
    7. HTC One Mini Motherboard Replacement: step 12, image 1 of 2 HTC One Mini Motherboard Replacement: step 12, image 2 of 2
      • Carefully disconnect the flex cables at the points where you removed the yellow tape in the previous steps.
      • To disconnect, flip up the small latch on each connector, opposite its cable, and then gently pull the cable free.
      Ask FixBot
    8. HTC One Mini Motherboard Replacement: step 13, image 1 of 3 HTC One Mini Motherboard Replacement: step 13, image 2 of 3 HTC One Mini Motherboard Replacement: step 13, image 3 of 3
      • Peel off the silver strip with your tweezers.
      • Using your hands, detach the black strip from the board without removing it.
      Ask FixBot
    9. HTC One Mini Motherboard Replacement: step 14, image 1 of 2 HTC One Mini Motherboard Replacement: step 14, image 2 of 2
      • Detach carefully with your tweezers the volume buttons.
      • Detach the power button with your tweezers.
      Ask FixBot
    10. HTC One Mini Motherboard Replacement: step 15, image 1 of 3 HTC One Mini Motherboard Replacement: step 15, image 2 of 3 HTC One Mini Motherboard Replacement: step 15, image 3 of 3
      • Identify the screw behind the cable.
      • Remove the screw using a Phillips screwdriver.
      Ask FixBot
    11. HTC One Mini Motherboard Replacement: step 16, image 1 of 2 HTC One Mini Motherboard Replacement: step 16, image 2 of 2
      • Lift the motherboard, but don't try to remove it completely yet.
      • Handle the board only by the edges.
      Ask FixBot
    12. HTC One Mini Motherboard Replacement: step 17, image 1 of 3 HTC One Mini Motherboard Replacement: step 17, image 2 of 3 HTC One Mini Motherboard Replacement: step 17, image 3 of 3
      • Using your tweezers, remove the black square located in the power button.
      • Remove the motherboard completely.
      Ask FixBot
Author
with
Daniela Delgado
577 Reputation
2 Guides authored
USF Tampa, Team 3-4, Brown Fall 2014 Member of USF Tampa, Team 3-4, Brown Fall 2014
USFT-BROWN-F14S3G4
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 15
Past 30 Days: 96
All Time: 5,779
