Up to 20% off select tools
HTC One Mini LCD Display Replacement
Views: 49K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
103
All Time:
49,390
Comments: 2
2 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
Use this guide to successfully remove your HTC One Mini's front speaker grill and then remove your LCD Screen so that it may be replaced.
    1. HTC One Mini LCD Display Replacement, iOpener Heating: step 1, image 1 of 1
      • Use the iOpener to melt the glue off of the top and bottom speaker grills.
      Ask FixBot
    2. HTC One Mini LCD Display Replacement, Remove Speaker Grills: step 2, image 1 of 1
      • Use the blue plastic opening tool to pry and remove the bottom speaker grill.
      Ask FixBot
    3. HTC One Mini LCD Display Replacement, Remove Screw: step 3, image 1 of 3 HTC One Mini LCD Display Replacement, Remove Screw: step 3, image 2 of 3 HTC One Mini LCD Display Replacement, Remove Screw: step 3, image 3 of 3
      • Remove the screw under speaker grill using a T6 Torx screwdriver.
      Ask FixBot
    4. HTC One Mini LCD Display Replacement: step 4, image 1 of 3 HTC One Mini LCD Display Replacement: step 4, image 2 of 3 HTC One Mini LCD Display Replacement: step 4, image 3 of 3
      • Wedge the plastic opening tool between the screen and the edge of the case.
      • Use force to pry and separate the rear panel.
      Ask FixBot
    5. HTC One Mini LCD Display Replacement, Separate Rear Case: step 5, image 1 of 2 HTC One Mini LCD Display Replacement, Separate Rear Case: step 5, image 2 of 2
      • Separate the rear panel from the phone.
      Ask FixBot
    6. HTC One Mini LCD Display Replacement: step 6, image 1 of 2 HTC One Mini LCD Display Replacement: step 6, image 2 of 2
      • Using the plastic opening tool, pry on the screen to separate it from the adhesive holding it.
      Ask FixBot
    7. HTC One Mini LCD Display Replacement, Separate LCD Screen: step 7, image 1 of 2 HTC One Mini LCD Display Replacement, Separate LCD Screen: step 7, image 2 of 2
      • After you have used the opening tool to pry, use some force to separate the LCD screen from the glue.
      Ask FixBot
12 other people completed this guide.
Author
with
Chris Jose
735 Reputation
2 Guides authored
USF Tampa, Team 3-4, Brown Fall 2014 Member of USF Tampa, Team 3-4, Brown Fall 2014
USFT-BROWN-F14S3G4
3 Members
60 Guides authored
2 Guide Comments
I have bought a new lcd digitizer for an htc m8 mini 2….I've assemble it and when i have turned the power on all i got was a light coming on… no displays on the screen…what could be the issue??
Ramon Alex Headley - Reply Share
Is it easier to fix if only the screen glass is broken and not the LCD?
myshepherd - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 103
All Time: 49,390
