Up to 20% off select tools
HTC One Mini Battery Replacement
Views: 47K
View statistics:
Past 24 Hours:
3
Past 7 Days:
12
Past 30 Days:
96
All Time:
46,806
Comments: 8
2 comments on steps, 6 guide comments.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 11
11 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
Follow the instructions in this repair guide to successfully remove the rear case of your HTC One Mini, locate the phone's battery, and remove it so that a new one may replace it.
    1. HTC One Mini Battery Replacement, iOpener Heating: step 1, image 1 of 1
      • Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
      Ask FixBot
    2. HTC One Mini Battery Replacement, Remove Speaker Grills: step 2, image 1 of 1
      • Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
      • Remove the lower speaker cover.
      Ask FixBot
    3. HTC One Mini Battery Replacement, Remove Screw: step 3, image 1 of 3 HTC One Mini Battery Replacement, Remove Screw: step 3, image 2 of 3 HTC One Mini Battery Replacement, Remove Screw: step 3, image 3 of 3
      • Remove the screw under the speaker cover using a T6 Torx screwdriver.
      Ask FixBot
    4. HTC One Mini Battery Replacement: step 4, image 1 of 3 HTC One Mini Battery Replacement: step 4, image 2 of 3 HTC One Mini Battery Replacement: step 4, image 3 of 3
      • Slide a thin guitar pick or pry tool between the edge of the display and the rear case, near the bottom of the phone.
      • Carefully work your way up each side of the display and separate the rear case. There are three clips on each side.
      Ask FixBot
    5. HTC One Mini Battery Replacement, Separate Rear Case: step 5, image 1 of 2 HTC One Mini Battery Replacement, Separate Rear Case: step 5, image 2 of 2
      • Remove the rear case from the phone.
      Ask FixBot
    1. HTC One Mini Battery Replacement, Remove Screws: step 6, image 1 of 3 HTC One Mini Battery Replacement, Remove Screws: step 6, image 2 of 3 HTC One Mini Battery Replacement, Remove Screws: step 6, image 3 of 3
      • Remove the two Phillips screws securing the battery connector.
      Ask FixBot
    2. HTC One Mini Battery Replacement: step 7, image 1 of 2 HTC One Mini Battery Replacement: step 7, image 2 of 2
      • Disconnect the battery by prying the metal cover straight up.
      Ask FixBot
    3. HTC One Mini Battery Replacement, Remove screws: step 8, image 1 of 3 HTC One Mini Battery Replacement, Remove screws: step 8, image 2 of 3 HTC One Mini Battery Replacement, Remove screws: step 8, image 3 of 3
      • Remove two Phillips screws.
      • The screw on the upper right corner secures a tiny golden washer. Remove this washer.
      Ask FixBot
    4. HTC One Mini Battery Replacement, Remove Screws: step 9, image 1 of 3 HTC One Mini Battery Replacement, Remove Screws: step 9, image 2 of 3 HTC One Mini Battery Replacement, Remove Screws: step 9, image 3 of 3
      • Remove the two small black Phillips screws.
      Ask FixBot
    5. HTC One Mini Battery Replacement, Remove Screws: step 10, image 1 of 3 HTC One Mini Battery Replacement, Remove Screws: step 10, image 2 of 3 HTC One Mini Battery Replacement, Remove Screws: step 10, image 3 of 3
      • Remove two more Phillips screws.
      Ask FixBot
    6. HTC One Mini Battery Replacement, Remove protective foil.: step 11, image 1 of 3 HTC One Mini Battery Replacement, Remove protective foil.: step 11, image 2 of 3 HTC One Mini Battery Replacement, Remove protective foil.: step 11, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to remove the yellow tape covering the flex cable connectors (total of five).
      Ask FixBot
    7. HTC One Mini Battery Replacement: step 12, image 1 of 2 HTC One Mini Battery Replacement: step 12, image 2 of 2
      • Carefully disconnect the flex cables at the points where you removed the yellow tape in the previous steps.
      • To disconnect, flip up the small latch on each connector, opposite its cable, and then gently pull the cable free.
      Ask FixBot
    8. HTC One Mini Battery Replacement: step 13, image 1 of 3 HTC One Mini Battery Replacement: step 13, image 2 of 3 HTC One Mini Battery Replacement: step 13, image 3 of 3
      • Peel off the silver strip with your tweezers.
      • Using your hands, detach the black strip from the board without removing it.
      Ask FixBot
    9. HTC One Mini Battery Replacement: step 14, image 1 of 2 HTC One Mini Battery Replacement: step 14, image 2 of 2
      • Detach carefully with your tweezers the volume buttons.
      • Detach the power button with your tweezers.
      Ask FixBot
    10. HTC One Mini Battery Replacement: step 15, image 1 of 3 HTC One Mini Battery Replacement: step 15, image 2 of 3 HTC One Mini Battery Replacement: step 15, image 3 of 3
      • Identify the screw behind the cable.
      • Remove the screw using a Phillips screwdriver.
      Ask FixBot
    11. HTC One Mini Battery Replacement: step 16, image 1 of 2 HTC One Mini Battery Replacement: step 16, image 2 of 2
      • Lift the motherboard, but don't try to remove it completely yet.
      • Handle the board only by the edges.
      Ask FixBot
    12. HTC One Mini Battery Replacement: step 17, image 1 of 3 HTC One Mini Battery Replacement: step 17, image 2 of 3 HTC One Mini Battery Replacement: step 17, image 3 of 3
      • Using your tweezers, remove the black square located in the power button.
      • Remove the motherboard completely.
      Ask FixBot
    1. HTC One Mini Battery Replacement, Remove Lower Speaker: step 18, image 1 of 3 HTC One Mini Battery Replacement, Remove Lower Speaker: step 18, image 2 of 3 HTC One Mini Battery Replacement, Remove Lower Speaker: step 18, image 3 of 3
      • Using the spudger, use force to detach and remove the speaker.
      Ask FixBot
    2. HTC One Mini Battery Replacement: step 19, image 1 of 3 HTC One Mini Battery Replacement: step 19, image 2 of 3 HTC One Mini Battery Replacement: step 19, image 3 of 3
      • Use a wide pry tool or credit card to gently pry the battery up and out of the phone.
      • Do not puncture or deform the battery in any way, or a dangerous fire or explosion may result.
      Ask FixBot
11 other people completed this guide.
Author
with
Daniela Delgado
577 Reputation
2 Guides authored
USF Tampa, Team 3-4, Brown Fall 2014 Member of USF Tampa, Team 3-4, Brown Fall 2014
USFT-BROWN-F14S3G4
3 Members
60 Guides authored
6 Guide Comments
I accidently teared the power button cable a little.
I guess i will have to buy a new one, but i wonder is it soldered ?
I don't think so but i'm not sure.
Is there a nother way to power it on for now ?
rssd - Reply Share
Please tell me,can i use battery from htc one mini 2 in htc one mini? I just want increase the battery capacity from 1800 to 2100.thanks for the answer
marat ospanov - Reply Share
I completed the steps as described and have an issue with my display now. I tried to start the device before pressing it in the back cover to check whether it works or not. It seems to work, but the display don't. Which cable is that of the display and / or what could have gone wrong? Thx!
tobiasemmert - Reply Share
I changed the battery, but now, the sound doesn't works. The microphone and the diffuser do not work. What can I do ?
niculoiualina - Reply Share
Just ruined my phone thanks to the worst ever tutorial i’ve ever seen.
Crispy K - Reply Share
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 96
All Time: 46,806
