Up to 20% off select tools
HTC One Mini 2 Battery Replacement
Views: 43K
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
108
All Time:
43,454
Comments: 13
10 comments on steps, 3 guide comments.
Go to guide comments
Completed: 23
23 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. HTC One Mini 2 Battery Replacement, Sim and MicroSD Card: step 1, image 1 of 3 HTC One Mini 2 Battery Replacement, Sim and MicroSD Card: step 1, image 2 of 3 HTC One Mini 2 Battery Replacement, Sim and MicroSD Card: step 1, image 3 of 3
      • Insert the end of a paper clip into the holes on each side of the phone to eject the SIM card and Micro SD card.
      • Set the cardholders aside.
      Ask FixBot
    2. HTC One Mini 2 Battery Replacement: step 2, image 1 of 1
      • Heat up the top grey speaker plate with the iFixit iOpener for two minutes.
      Ask FixBot
    3. HTC One Mini 2 Battery Replacement, Front Plate: step 3, image 1 of 3 HTC One Mini 2 Battery Replacement, Front Plate: step 3, image 2 of 3 HTC One Mini 2 Battery Replacement, Front Plate: step 3, image 3 of 3
      • Use a metal spudger to pry up the left edge of the upper grey front plate.
      • Place the spudger between the inside white plastic edge and the grey plate. Do not pry between the two white plastic frames.
      • Don’t pry against the glass. Pry against only the left side as there is a delicate antenna under the plate.
      • Use the narrow plastic pry tool to carefully separate the black ribbon antenna from the grey plate.
      Ask FixBot
    4. HTC One Mini 2 Battery Replacement: step 4, image 1 of 2 HTC One Mini 2 Battery Replacement: step 4, image 2 of 2
      • Remove the 2mm screw with a T5 torx screwdriver head from the iFixit tool kit.
      Ask FixBot
    5. HTC One Mini 2 Battery Replacement: step 5, image 1 of 2 HTC One Mini 2 Battery Replacement: step 5, image 2 of 2
      • Use the plastic pry tool to pry around the edge of the phone.
      • Pry carefully around the card slots.
      • Slowly pull up from the right side of the screen like opening a book.
      • The plastic piece for the power button may fall out. Set it aside for reassembly.
      • Use the plastic spudger to peel the foam adhesive around the camera away from the back plate.
      Ask FixBot
    1. HTC One Mini 2 Battery Replacement, Motherboard: step 6, image 1 of 2 HTC One Mini 2 Battery Replacement, Motherboard: step 6, image 2 of 2
      • Peel off the long yellow pieces of tape on the right and left side of the copper plate.
      Ask FixBot
    2. HTC One Mini 2 Battery Replacement: step 7, image 1 of 1
      • Starting from the copper plate, peel up all three woven, silver colored tapes using the spudger or narrow pry tool.
      Ask FixBot
    3. HTC One Mini 2 Battery Replacement: step 8, image 1 of 3 HTC One Mini 2 Battery Replacement: step 8, image 2 of 3 HTC One Mini 2 Battery Replacement: step 8, image 3 of 3
      • Using the flat end of the spudger, pop up the white tabs on all ribbon cable connectors located to the left and right of the copper plate.
      • On the left side, pop the white tab up to the left. On the right, pop up to the right.
      • Carefully pull out the ribbon cables.
      Ask FixBot
    4. HTC One Mini 2 Battery Replacement: step 9, image 1 of 3 HTC One Mini 2 Battery Replacement: step 9, image 2 of 3 HTC One Mini 2 Battery Replacement: step 9, image 3 of 3
      • Using a Phillips #00 screwdriver, unscrew the two 1 mm screws from the bottom right corner of the motherboard that hold the power connector down.
      • Pop up the battery connector using the flat end of the spudger.
      Ask FixBot
    5. HTC One Mini 2 Battery Replacement: step 10, image 1 of 3 HTC One Mini 2 Battery Replacement: step 10, image 2 of 3 HTC One Mini 2 Battery Replacement: step 10, image 3 of 3
      • Use the pointed end of the spudger to pop off the four antenna connectors. Three are located on the top left corner of the motherboard and one on the bottom right.
      Ask FixBot
    6. HTC One Mini 2 Battery Replacement: step 11, image 1 of 2 HTC One Mini 2 Battery Replacement: step 11, image 2 of 2
      • Using the pointed end of the spudger, pull the wires for the rumble motor to the left to pull the connector out of the board.
      • The connector is very small and easy to break so take caution when pulling it out. Wiggling the wires as you pull to the left helps.
      Ask FixBot
    7. HTC One Mini 2 Battery Replacement: step 12, image 1 of 3 HTC One Mini 2 Battery Replacement: step 12, image 2 of 3 HTC One Mini 2 Battery Replacement: step 12, image 3 of 3
      • Using a T5 torx screwdriver, remove four 2mm screws from the four corners of the motherboard.
      • Once the screws are removed, carefully pull the copper plated motherboard out.
      Ask FixBot
    1. HTC One Mini 2 Battery Replacement, Battery: step 13, image 1 of 3 HTC One Mini 2 Battery Replacement, Battery: step 13, image 2 of 3 HTC One Mini 2 Battery Replacement, Battery: step 13, image 3 of 3
      • Use the narrow plastic pry tool to pop off the two ribbon cable connectors located at the bottom of the upper circuit board.
      Ask FixBot
    2. HTC One Mini 2 Battery Replacement: step 14, image 1 of 1
      • Use a prying motion on each side of the battery with the narrow plastic pry tool to lift the battery from the frame and remove it.
      • There is an adhesive under the battery. This may take some extra work to pry off.
      Ask FixBot
23 other people completed this guide.
Author
with
Jeron Hogan
818 Reputation
3 Guides authored
Cal Poly, Team 4-48, Amido Fall 2014 Member of Cal Poly, Team 4-48, Amido Fall 2014
CPSU-AMIDO-F14S4G48
5 Members
84 Guides authored
3 Guide Comments
I just went through this with my phone and got it all back together, but I just plugged it in to charge and the screen just shows a gray blob slowly getting darker until the LED charging light shuts off and the screen goes blank. I don’t know if maybe I missed connecting something or what. Any suggestions on what may be unplugged/damaged?
Anthony - Reply Share
Same here, Anthony. Did you ever resolve grey blob problem?
Don - Reply Share
funny I got the same problem, the charge light stays on and if you press vol dn and power button at same time it buzzes after 5 seconds
gordon beaton - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 108
All Time: 43,454
