Up to 20% off select tools
HTC One Mini 2 Back Plate Replacement
Views: 11K
View statistics:
Past 24 Hours:
7
Past 7 Days:
22
Past 30 Days:
104
All Time:
11,182
Comments: 9
8 comments on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to help open up the HTC One Mini 2 and replace the back plate. It is helpful if you want to replace the back plate for cosmetic reasons.
    1. HTC One Mini 2 Back Plate Replacement, Sim and MicroSD Card: step 1, image 1 of 3 HTC One Mini 2 Back Plate Replacement, Sim and MicroSD Card: step 1, image 2 of 3 HTC One Mini 2 Back Plate Replacement, Sim and MicroSD Card: step 1, image 3 of 3
      • Insert the end of a paper clip into the holes on each side of the phone to eject the SIM card and Micro SD card.
      • Set the cardholders aside.
      Ask FixBot
    2. HTC One Mini 2 Back Plate Replacement: step 2, image 1 of 1
      • Heat up the top grey speaker plate with the iFixit iOpener for two minutes.
      Ask FixBot
    3. HTC One Mini 2 Back Plate Replacement, Front Plate: step 3, image 1 of 3 HTC One Mini 2 Back Plate Replacement, Front Plate: step 3, image 2 of 3 HTC One Mini 2 Back Plate Replacement, Front Plate: step 3, image 3 of 3
      • Use a metal spudger to pry up the left edge of the upper grey front plate.
      • Place the spudger between the inside white plastic edge and the grey plate. Do not pry between the two white plastic frames.
      • Don’t pry against the glass. Pry against only the left side as there is a delicate antenna under the plate.
      • Use the narrow plastic pry tool to carefully separate the black ribbon antenna from the grey plate.
      Ask FixBot
    4. HTC One Mini 2 Back Plate Replacement: step 4, image 1 of 2 HTC One Mini 2 Back Plate Replacement: step 4, image 2 of 2
      • Remove the 2mm screw with a T5 torx screwdriver head from the iFixit tool kit.
      Ask FixBot
    5. HTC One Mini 2 Back Plate Replacement: step 5, image 1 of 2 HTC One Mini 2 Back Plate Replacement: step 5, image 2 of 2
      • Use the plastic pry tool to pry around the edge of the phone.
      • Pry carefully around the card slots.
      • Slowly pull up from the right side of the screen like opening a book.
      • The plastic piece for the power button may fall out. Set it aside for reassembly.
      • Use the plastic spudger to peel the foam adhesive around the camera away from the back plate.
      Ask FixBot
5 other people completed this guide.
Author
with
Caleb Kelsay
590 Reputation
1 Guide authored
Cal Poly, Team 4-48, Amido Fall 2014 Member of Cal Poly, Team 4-48, Amido Fall 2014
CPSU-AMIDO-F14S4G48
5 Members
84 Guides authored
1 Guide Comment
what is the black ribbon antenna on the front
deancvijic90 - Reply Share
Past 24 Hours: 7
Past 7 Days: 22
Past 30 Days: 104
All Time: 11,182
