Tools
Spudger4.9
Introduction
Go to step 1 ↓You will learn how to replace your rear camera in this guide.
Lift back cover while pressing highlighted release switch towards the center of the phone.
Tool used on this step:Tweezers$4.99
Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
Use a plastic tool to remove the ribbon cable.
Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
Remove the three 3 mm Phillips #000 screws from the secondary board at the top.
8 other people completed this guide.
1 Guide Comment
so..which one do i have to buy?
the Phillips #00 or the #000? the steps say one thing, the required tools section says another.
thanks in advance
