Up to 20% off select tools
HTC One Max IR Blaster Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
99
All Time:
2,354
Comments: 6
6 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a broken or defective IR blaster.
    1. HTC One Max IR Blaster Replacement, Back Case: step 1, image 1 of 1
      • Lift back cover while pressing highlighted release switch towards the center of the phone.
      Ask FixBot
    2. HTC One Max IR Blaster Replacement: step 2, image 1 of 2 HTC One Max IR Blaster Replacement: step 2, image 2 of 2
      • Remove the four white stickers in each corner that cover the Tri-Wing screws.
      • Remove the white sticker near the buttons that control the volume.
      • Remove the white sticker near the SIM card.
      • Remove the big white sticker with the bar-code in the center of the phone.
      Ask FixBot
    3. HTC One Max IR Blaster Replacement: step 3, image 1 of 1
      • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
      • Disconnect the cable near the volume buttons.
      Ask FixBot
    4. HTC One Max IR Blaster Replacement: step 4, image 1 of 2 HTC One Max IR Blaster Replacement: step 4, image 2 of 2
      • Use the small plastic opening tool to pry between the screen and the rear case.
      Ask FixBot
    1. HTC One Max IR Blaster Replacement, Fingerprint Sensor: step 5, image 1 of 2 HTC One Max IR Blaster Replacement, Fingerprint Sensor: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
      • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
      Ask FixBot
    1. HTC One Max IR Blaster Replacement, Motherboard: step 6, image 1 of 2 HTC One Max IR Blaster Replacement, Motherboard: step 6, image 2 of 2
      • Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
      • Use a plastic tool to remove the ribbon cable.
      Ask FixBot
    2. HTC One Max IR Blaster Replacement: step 7, image 1 of 2 HTC One Max IR Blaster Replacement: step 7, image 2 of 2
      • Use the plastic opening tool to disconnect the two antenna wires at the top of the phone.
      • Use the plastic opening tool to disconnect a third antenna wire at the bottom of the phone.
      Ask FixBot
    3. HTC One Max IR Blaster Replacement: step 8, image 1 of 1
      • Remove the seven 3 mm Phillips #000 screws from the motherboard.
      Ask FixBot
    4. HTC One Max IR Blaster Replacement: step 9, image 1 of 3 HTC One Max IR Blaster Replacement: step 9, image 2 of 3 HTC One Max IR Blaster Replacement: step 9, image 3 of 3
      • Use a plastic tool to pry up and disconnect the large ribbon cables on each side of the motherboard.
      • Use caution prying the ribbon cable on the right side because other ribbon cables run under it.
      Ask FixBot
    5. HTC One Max IR Blaster Replacement: step 10, image 1 of 3 HTC One Max IR Blaster Replacement: step 10, image 2 of 3 HTC One Max IR Blaster Replacement: step 10, image 3 of 3
      • Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
      • Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
      Ask FixBot
    6. HTC One Max IR Blaster Replacement: step 11, image 1 of 2 HTC One Max IR Blaster Replacement: step 11, image 2 of 2
      • Use a plastic tool to lift and remove the motherboard.
      • Use a heat gun to loosen adhesive at bottom if needed.
      Ask FixBot
    1. HTC One Max IR Blaster Replacement, IR Blaster: step 12, image 1 of 1
      • Remove the three 3 mm Phillips #000 screws from the secondary board at the top.
      Ask FixBot
    2. HTC One Max IR Blaster Replacement: step 13, image 1 of 1
      • Pick up and set aside vibrator, do not disconnect.
      Ask FixBot
    3. HTC One Max IR Blaster Replacement: step 14, image 1 of 1
      • Pull out ribbon cable.
      • Peel back infrared sensor.
      Ask FixBot
3 other people completed this guide.
Author
with
Andrew Keller
1,131 Reputation
5 Guides authored
USF Tampa, Team 11-3, Blackwell Fall 2014 Member of USF Tampa, Team 11-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 99
All Time: 2,354
