Up to 20% off select tools
HTC One M8 Motherboard Replacement
Views: 27K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
222
All Time:
27,135
Comments: 50
48 comments on steps, 2 guide comments.
Go to guide comments
Completed: 28
28 people have marked this guide "completed." Will you be next?
Favorites: 18
18 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 - 35 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the motherboard on your HTC One M8.
Please note that your device may have a large amount of copper shielding and tape covering the back of the display assembly, as shown here. If this is the case, you'll need to gently remove it to get at the motherboard.
    1. HTC One M8 Motherboard Replacement, SIM Card: step 1, image 1 of 2 HTC One M8 Motherboard Replacement, SIM Card: step 1, image 2 of 2
      • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the upper left hand side of the phone.
      • Press to eject the tray.
      • This may require a significant amount of force.
      Ask FixBot
    2. HTC One M8 Motherboard Replacement: step 2, image 1 of 1
      • Remove the SIM card tray assembly from the HTC One M8.
      • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
      Ask FixBot
    1. HTC One M8 Motherboard Replacement, MicroSD Card: step 3, image 1 of 2 HTC One M8 Motherboard Replacement, MicroSD Card: step 3, image 2 of 2
      • Insert a SIM card eject tool or a paperclip into the small hole in the microSD card tray, located on the upper right hand side of the phone.
      Ask FixBot
    2. HTC One M8 Motherboard Replacement: step 4, image 1 of 1
      • Remove the microSD card tray assembly from the HTC One M8.
      • When reinserting the microSD card, ensure that it is in the proper orientation relative to the tray.
      Ask FixBot
    1. HTC One M8 Motherboard Replacement, Rear Case: step 5, image 1 of 2 HTC One M8 Motherboard Replacement, Rear Case: step 5, image 2 of 2
      • Use an iOpener or heat gun to loosen the adhesive on the upper and lower speaker grilles.
      • Refer to the iOpener guide for info on how to use the iOpener.
      Ask FixBot
    2. HTC One M8 Motherboard Replacement: step 6, image 1 of 3 HTC One M8 Motherboard Replacement: step 6, image 2 of 3 HTC One M8 Motherboard Replacement: step 6, image 3 of 3
      • Use a plastic opening tool to gently peel up the lower speaker grille.
      • The adhesive is messy, and can be removed using Goo-gone.
      Ask FixBot
    3. HTC One M8 Motherboard Replacement: step 7, image 1 of 2 HTC One M8 Motherboard Replacement: step 7, image 2 of 2
      • Use a plastic opening tool to gently peel up the upper speaker grille.
      Ask FixBot
    4. HTC One M8 Motherboard Replacement: step 8, image 1 of 1
      • Remove the two silver 3 mm Phillips #00 screws from the top.
      • Remove the four black 4 mm T5 Torx screws from the bottom.
      Ask FixBot
    5. HTC One M8 Motherboard Replacement: step 9, image 1 of 3 HTC One M8 Motherboard Replacement: step 9, image 2 of 3 HTC One M8 Motherboard Replacement: step 9, image 3 of 3
      • Work your way around the perimeter of the phone with a spudger and plastic opening picks to free the clips that secure the rear case to the display assembly.
      • A metal spudger is pictured, but it is best to use a nylon spudger to prevent marring the device.
      • Be careful not to lose the power button: it sits loosely in the top of the lower chassis.
      • Significant force may be required to pry the casing apart.
      Ask FixBot
    1. HTC One M8 Motherboard Replacement, Motherboard: step 10, image 1 of 2 HTC One M8 Motherboard Replacement, Motherboard: step 10, image 2 of 2
      • Remove the two silver 2 mm Phillips #00 screws securing the battery connector to the motherboard.
      • Use a plastic opening tool to gently pry up the battery connector.
      Ask FixBot
    2. HTC One M8 Motherboard Replacement: step 11, image 1 of 3 HTC One M8 Motherboard Replacement: step 11, image 2 of 3 HTC One M8 Motherboard Replacement: step 11, image 3 of 3
      Tool used on this step:
      Buy
      • Use a spudger to disconnect the two (four) antenna cables.
      • Use the tip of a spudger to disconnect the seven ZIF connectors.
      • Use a pair of tweezers to gently pull the seven ribbon cables free of the connectors.
      Ask FixBot
    3. HTC One M8 Motherboard Replacement: step 12, image 1 of 1
      • Remove three silver 3mm screws using T5 screwdriver.
      Ask FixBot
    4. HTC One M8 Motherboard Replacement: step 13, image 1 of 3 HTC One M8 Motherboard Replacement: step 13, image 2 of 3 HTC One M8 Motherboard Replacement: step 13, image 3 of 3
      • Use an iOpener or a heat gun to loosen up the adhesive securing the motherboard to the display assembly.
      • Use a plastic opening tool to gently pry the motherboard free of the display assembly.
      • At this point, the bottom speaker is still attached to the motherboard. If you are only replacing the motherboard, refer to the bottom speaker guide to swap your existing speaker to the new motherboard.
      Ask FixBot
28 other people completed this guide.
Author
with
Michael Gonzalez
4,448 Reputation
5 Guides authored
Cal Poly, Team 5-9, Maness Spring 2015 Member of Cal Poly, Team 5-9, Maness Spring 2015
CPSU-MANESS-S15S5G9
4 Members
72 Guides authored
2 Guide Comments
Thanks you very much
ngvhiem26 - Reply Share
all ok. thanks.
Javier - Reply Share
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 222
All Time: 27,135
