Up to 20% off select tools
HTC One Battery Replacement
Views: 132K
View statistics:
Past 24 Hours:
3
Past 7 Days:
33
Past 30 Days:
165
All Time:
132,496
Comments: 22
13 comments on steps, 9 guide comments.
Go to guide comments
Completed: 48
48 people have marked this guide "completed." Will you be next?
Favorites: 18
18 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 hours
Difficulty: Very difficult
Parts
Tools
Introduction
Go to step 1 ↓
If you have an issue with your battery as described in the troubleshooting guide, this guide will instruct you on replacing your battery.
Video Overview
    1. HTC One Battery Replacement, Battery: step 1, image 1 of 1
      • In this step you'll lift the screen. Be VERY gentle else you will break it. Insert the plastic opening tool in between the black plastic bezel and the glass screen edge along the sides and the top, gently loosening the adhesive. The screen will remain attached at the bottom edge, as if on a hinge.
      • You may need to use a hair dryer or hot air gun to loosen the adhesive holding the device together. Be careful not to heat the device too much however as you could cause damage!
      Ask FixBot
    2. HTC One Battery Replacement: step 2, image 1 of 1
      • Wedge the plastic opening tool into the crack around the screen on the top, left and right sides.
      Ask FixBot
    3. HTC One Battery Replacement: step 3, image 1 of 1
      • Once the screen has been loosened on the top, left and right edges, lift the screen.
      • The screen will stay on a hinge until the final step.
      Ask FixBot
    4. HTC One Battery Replacement: step 4, image 1 of 1
      • The rear case is held on by glue and eight tabs on the screen bezel. On the volume side there is one above the rocker and three below; on the SIM side all are below the slot. Insert the plastic opening tool between the case edge and the screen bezel, aiming to prise the rear case edge outwards to loosen the glue and free the tabs, one at a time.
      Ask FixBot
    5. HTC One Battery Replacement: step 5, image 1 of 1
      • Pry the back open once loose and lift. The back panel will come off with time.
      Ask FixBot
    6. HTC One Battery Replacement: step 6, image 1 of 1
      • Remove all the #000 screws with a #000 Phillips screw driver.
      • Some screws are hidden by tape so remove the tape and check for screws.
      Ask FixBot
    7. HTC One Battery Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Lift the motherboard completely out of the phone with the tweezers. (may stay attached at the bottom by tape)
      Ask FixBot
    8. HTC One Battery Replacement: step 8, image 1 of 1
      • Use the blue opening tool to pry up the battery from the frame.
      • The battery is glued to the frame so you will have to put force.
      • Do not break the battery upon removal.
      Ask FixBot
48 other people completed this guide.
Author
with
AJ Skiles
3,547 Reputation
1 Guide authored
USF Tampa, Team 12-1, Blackwell Fall 2014 Member of USF Tampa, Team 12-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G1
4 Members
60 Guides authored
9 Guide Comments
Removing the screen first may make it easier to insert the plastic tool between the bezel and the case, however in my instance despite being as careful as I was able I still damaged the screen whilst doing this.
Furthermore, since both the bezel and the case edge are plastic I found that they were not strong enough to withstand damage whilst I loosened the glue that held them together. Whilst I was able to access and replace the battery, cosmetically speaking the phone is a ruin.
Hardest device disassembly I have _ever_ attempted.
Ian Silvester - Reply Share
Why do you need to remove the screen? Step 3 says the screen will stay hinged until the final step, but after step 3 there is no more mention of the screen.
Leo Taro - Reply Share
I got away without prying the LCD off (omitting step 2+3). I was lucky and the back coverpopped off rather easily. All in all it took me about an hour.
Christian Egger - Reply Share
If i change batterry finish.
Do I have to use glue to put the screen back on the body?
Viriya Nopparat - Reply Share
Where can I get a new battery
Felix - Reply Share
Past 24 Hours: 3
Past 7 Days: 33
Past 30 Days: 165
All Time: 132,496
