This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
HTC One A9s replacement battery replacement
      • Start at the selfie camera and carefully pry up the screen.
      Ask FixBot
    1. HTC One A9s replacement battery replacement, Disconnect the display connectors: step 2, image 1 of 1
      • Remove the display connector cover.
      • Disconnect the two connectors.
      Ask FixBot
    2. HTC One A9s replacement battery replacement, Release the screws: step 3, image 1 of 1
      Tool used on this step:
      Phillips #00 Screwdriver
      $5.49
      Buy
      Ask FixBot
    3. HTC One A9s replacement battery replacement, Remove the back cover: step 4, image 1 of 1
      • Carefully remove the back cover of the device.
      Ask FixBot
    4. HTC One A9s replacement battery replacement, Disconnect the replacement battery: step 5, image 1 of 1
      • Carefully lift the replacement battery connector. Do not pull!
      Ask FixBot
    5. HTC One A9s replacement battery replacement, Remove the replacement battery: step 6, image 1 of 1
      Jimmy
      $7.95
      Buy
      • Starting at the bottom left with the Jimmy, carefully pry the replacement battery out. Work your way to the right and then up.
      • If the replacement battery is still stuck on the right side, carefully pull it off.
      Ask FixBot
    6. HTC One A9s replacement battery replacement, Install the replacement battery: step 7, image 1 of 1
      • Position the replacement battery and insert the connector vertically into its slot. Bend the cable slightly to the left if necessary.
      Ask FixBot
    7. HTC One A9s replacement battery replacement, Install the back cover: step 8, image 1 of 1
      • Place the back cover back onto the device and fasten the 14 screws in a star pattern.
      Ask FixBot
    8. HTC One A9s replacement battery replacement, Connect the display: step 9, image 1 of 1
      • Reconnect the display and secure the cover plate.
      Ask FixBot
    9. HTC One A9s replacement battery replacement, Test the replacement battery and close the device: step 10, image 1 of 1
      • Test the new replacement battery to make sure everything is working.
      • If the test is successful, close the device.
      Ask FixBot
Follow these steps in reverse order to reassemble your device. Ensure that all connections and screws are securely fastened before using the device.
Marten
806 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 58
All Time: 320
