This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓This guide explains how to detach the HTC One A9s display, disconnect the display connectors, and test-connect a new display.
This repair assumes the replacement of the entire display assembly. The display and touchscreen are bonded together and are replaced as a module.
Heat the top edge of the display with a heat gun or hair dryer.
Insert a Jimmy between the display and the housing at the top edge.
Separate the display from top to bottom.
Carefully pry up the display.
Use a screwdriver to disconnect the cover plate over the display connectors.
Disconnect the display cables.
Connect the new display and test it before you install it completely.
If the new display functions successfully, replace the cover plate and screw it on.
Before installing the new display, remove old adhesive residue from the adhesive surfaces. Use new display adhesive or a suitable gasket if you want to maintain water and dust protection as much as possible.
After reassembly, check that the new display is working correctly.
Special thanks to these translators:
100%
Juan Garcia is helping us fix the world! Want to contribute?
Start translating ›
