Up to 20% off select tools
HTC Hero Touch Screen Digitizer Replacement
Views: 4.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
91
All Time:
4,144
Comments: 0
Go to guide comments
Completed: 0
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Difficult
Needs More Images
A few more images would make this guide's procedures crystal clear.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
    1. HTC Hero Touch Screen Digitizer Replacement, Back Case: step 1, image 1 of 1
      • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
      • Remove both the battery and the SD card (Press SD card in to release)
      • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
      Ask FixBot
    2. HTC Hero Touch Screen Digitizer Replacement: step 2, image 1 of 1
      • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
      • Insert the flat end between the back and front enclosure, working your way around the rim.
      Ask FixBot
    3. HTC Hero Touch Screen Digitizer Replacement: step 3, image 1 of 1
      • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
      • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
      Ask FixBot
    4. HTC Hero Touch Screen Digitizer Replacement: step 4, image 1 of 2 HTC Hero Touch Screen Digitizer Replacement: step 4, image 2 of 2
      • Carefully separate the front and back enclosures once all of the clips have been disengaged.
      • Be sure to not separate too quickly or you risk breaking an attached tab.
      Ask FixBot
    1. HTC Hero Touch Screen Digitizer Replacement, Touch Screen: step 5, image 1 of 2 HTC Hero Touch Screen Digitizer Replacement, Touch Screen: step 5, image 2 of 2
      • Gently release the two ribbon cables using a plastic opening tool by prying up the pop connectors used to attach the ribbon cables to the motherboard.
      Ask FixBot
    2. HTC Hero Touch Screen Digitizer Replacement: step 6, image 1 of 2 HTC Hero Touch Screen Digitizer Replacement: step 6, image 2 of 2
      • Remove the two screws located at the bottom left and right of the motherboard using a small Phillips screwdriver.
      Ask FixBot
    3. HTC Hero Touch Screen Digitizer Replacement: step 7, image 1 of 2 HTC Hero Touch Screen Digitizer Replacement: step 7, image 2 of 2
      • Gently lift the motherboard out of the front enclosure once the screws are removed.
      Ask FixBot
    4. HTC Hero Touch Screen Digitizer Replacement: step 8, image 1 of 3 HTC Hero Touch Screen Digitizer Replacement: step 8, image 2 of 3 HTC Hero Touch Screen Digitizer Replacement: step 8, image 3 of 3
      • Remove the trackball and its enclosure by turning the phone over into your cupped hand and allowing the trackball and enclosure to fall out.
      Ask FixBot
    5. HTC Hero Touch Screen Digitizer Replacement: step 9, image 1 of 3 HTC Hero Touch Screen Digitizer Replacement: step 9, image 2 of 3 HTC Hero Touch Screen Digitizer Replacement: step 9, image 3 of 3
      • Gently pry out the LCD screen from the top left side of the enclosure using a plastic tool, as illustrated.
      Ask FixBot
    6. HTC Hero Touch Screen Digitizer Replacement: step 10, image 1 of 2 HTC Hero Touch Screen Digitizer Replacement: step 10, image 2 of 2
      • Using a plastic opening tool, gently pry the glass from the frame by inserting the flat end between the glass and the frame from the inside of the phone.
      • Follow the edges of the glass to ensure that all the adhesive has been released.
      Ask FixBot
    7. HTC Hero Touch Screen Digitizer Replacement: step 11, image 1 of 1
      • Using a heat lamp or gun, warm the glass to loosen the adhesive binding it to the frame.
      • Once the adhesive has been released, you should be able to remove the glass by pushing on it from the inside of the phone.
      • Be careful to remove the glass slowly. The ribbon cable that connects to the glass is routed through the plastic frame at the bottom.
      Ask FixBot
    8. HTC Hero Touch Screen Digitizer Replacement: step 12, image 1 of 3 HTC Hero Touch Screen Digitizer Replacement: step 12, image 2 of 3 HTC Hero Touch Screen Digitizer Replacement: step 12, image 3 of 3
      • Carefully feed the ribbon cable through the slot in the plastic frame.
      Ask FixBot
    9. HTC Hero Touch Screen Digitizer Replacement: step 13, image 1 of 1
      • Remove any excess adhesive from the plastic frame.
      Ask FixBot
Author
with
Max Brown
139 Reputation
4 Guides authored
Cal Poly, Team 3-26, Amido Winter 2012 Member of Cal Poly, Team 3-26, Amido Winter 2012
CPSU-AMIDO-W12S3G26
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 91
All Time: 4,144
