Up to 20% off select tools
HTC Hero Motherboard Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
90
All Time:
2,198
Comments: 0
Go to guide comments
Completed: 0
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
    1. HTC Hero Motherboard Replacement, Back Case: step 1, image 1 of 1
      • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
      • Remove both the battery and the SD card (Press SD card in to release)
      • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
      Ask FixBot
    2. HTC Hero Motherboard Replacement: step 2, image 1 of 1
      • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
      • Insert the flat end between the back and front enclosure, working your way around the rim.
      Ask FixBot
    3. HTC Hero Motherboard Replacement: step 3, image 1 of 1
      • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
      • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
      Ask FixBot
    4. HTC Hero Motherboard Replacement: step 4, image 1 of 2 HTC Hero Motherboard Replacement: step 4, image 2 of 2
      • Carefully separate the front and back enclosures once all of the clips have been disengaged.
      • Be sure to not separate too quickly or you risk breaking an attached tab.
      Ask FixBot
    1. HTC Hero Motherboard Replacement, Motherboard: step 5, image 1 of 2 HTC Hero Motherboard Replacement, Motherboard: step 5, image 2 of 2
      • Release the two ribbon cables using a plastic opening tool.
      • Gently pry up the pop connectors used to attach the ribbon cables to the motherboard.
      Ask FixBot
    2. HTC Hero Motherboard Replacement: step 6, image 1 of 2 HTC Hero Motherboard Replacement: step 6, image 2 of 2
      • Remove the two screws located at the bottom left and right of the motherboard using a small Phillips screwdriver.
      Ask FixBot
    3. HTC Hero Motherboard Replacement: step 7, image 1 of 2 HTC Hero Motherboard Replacement: step 7, image 2 of 2
      • Gently lift the motherboard out of the front enclosure once the screws are removed.
      Ask FixBot
Author
with
Rosalind Villalvazo
100 Reputation
2 Guides authored
Cal Poly, Team 3-26, Amido Winter 2012 Member of Cal Poly, Team 3-26, Amido Winter 2012
CPSU-AMIDO-W12S3G26
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 90
All Time: 2,198
