Up to 20% off select tools
HTC Hero Camera Replacement
Views: 2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
98
All Time:
2,021
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Parts
Tools
    1. HTC Hero Camera Replacement, Back Case: step 1, image 1 of 1
      • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
      • Remove both the battery and the SD card (Press SD card in to release)
      • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
      Ask FixBot
    2. HTC Hero Camera Replacement: step 2, image 1 of 1
      • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
      • Insert the flat end between the back and front enclosure, working your way around the rim.
      Ask FixBot
    3. HTC Hero Camera Replacement: step 3, image 1 of 1
      • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
      • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
      Ask FixBot
    4. HTC Hero Camera Replacement: step 4, image 1 of 2 HTC Hero Camera Replacement: step 4, image 2 of 2
      • Carefully separate the front and back enclosures once all of the clips have been disengaged.
      • Be sure to not separate too quickly or you risk breaking an attached tab.
      Ask FixBot
    1. HTC Hero Camera Replacement, Camera: step 5, image 1 of 3 HTC Hero Camera Replacement, Camera: step 5, image 2 of 3 HTC Hero Camera Replacement, Camera: step 5, image 3 of 3
      • Locate the four metal tabs on the top and bottom of the camera holding the camera enclosure to the motherboard.
      Ask FixBot
    2. HTC Hero Camera Replacement: step 6, image 1 of 2 HTC Hero Camera Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Using a pair of metal tweezers, simultaneously depress both tabs on one side of the camera enclosure and gently pull up until tabs come free. Repeat for the opposite side.
      Ask FixBot
    3. HTC Hero Camera Replacement: step 7, image 1 of 2 HTC Hero Camera Replacement: step 7, image 2 of 2
      • Pull the released camera enclosure away from the motherboard until it is completely free.
      Ask FixBot
    4. HTC Hero Camera Replacement: step 8, image 1 of 2 HTC Hero Camera Replacement: step 8, image 2 of 2
      • Now with camera unit exposed, gently wiggle the camera as you pull away from the phone to remove it.
      Ask FixBot
Author
with
Max Brown
139 Reputation
4 Guides authored
Cal Poly, Team 3-26, Amido Winter 2012 Member of Cal Poly, Team 3-26, Amido Winter 2012
CPSU-AMIDO-W12S3G26
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 98
All Time: 2,021
