Up to 20% off select tools
HTC Hero Back Case Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
95
All Time:
2,927
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
This guide is a helpful starting point for almost every hardware related replacement or installation. By exposing the internal components you will be able to repair, replace, or clean out the interior of your phone. While this process does require a few specific tools, they are widely available and do not require any previous experience to use them effectively.
    1. HTC Hero Back Case Replacement, Back Case: step 1, image 1 of 1
      • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
      • Remove both the battery and the SD card (Press SD card in to release)
      • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
      Ask FixBot
    2. HTC Hero Back Case Replacement: step 2, image 1 of 1
      • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
      • Insert the flat end between the back and front enclosure, working your way around the rim.
      Ask FixBot
    3. HTC Hero Back Case Replacement: step 3, image 1 of 1
      • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
      • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
      Ask FixBot
    4. HTC Hero Back Case Replacement: step 4, image 1 of 2 HTC Hero Back Case Replacement: step 4, image 2 of 2
      • Carefully separate the front and back enclosures once all of the clips have been disengaged.
      • Be sure to not separate too quickly or you risk breaking an attached tab.
      Ask FixBot
Author
with
Max Brown
139 Reputation
4 Guides authored
Cal Poly, Team 3-26, Amido Winter 2012 Member of Cal Poly, Team 3-26, Amido Winter 2012
CPSU-AMIDO-W12S3G26
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 95
All Time: 2,927
