Up to 20% off select tools
HTC HD2 Vibrator Replacement
Views: 6.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
84
All Time:
6,454
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
  • Spudger
    4.9
  • Tweezers
  • T5 Torx Screwdriver
    4.9
Introduction
Go to step 1 ↓
The vibrator is easy to find and remove after the housing has been taken off.
    1. HTC HD2 Vibrator Replacement, Battery: step 1, image 1 of 1
      • Carefully pull the rear cover from the back of the phone.
      • Place a finger beneath the small lip on the left side of the battery.
      Ask FixBot
    2. HTC HD2 Vibrator Replacement: step 2, image 1 of 2 HTC HD2 Vibrator Replacement: step 2, image 2 of 2
      • Lay the phone down on it's screen.
      • Lift up on the lip and pull the battery from the phone.
      Ask FixBot
    1. HTC HD2 Vibrator Replacement, Midframe: step 3, image 1 of 2 HTC HD2 Vibrator Replacement, Midframe: step 3, image 2 of 2
      • Remove the four black 3.5mm T5 screws from the back of the phone.
      Ask FixBot
    2. HTC HD2 Vibrator Replacement: step 4, image 1 of 2 HTC HD2 Vibrator Replacement: step 4, image 2 of 2
      • Insert the flat end of a spudger between the midframe and the display.
      • Slide the spudger along the seam between the frame and the display.
      • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
      • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
      • As it releases, pull the midframe away from the phone.
      • The volume control tab may fall off during removal. It can be easily reattached.
      Ask FixBot
    1. HTC HD2 Vibrator Replacement, Vibrator: step 5, image 1 of 2 HTC HD2 Vibrator Replacement, Vibrator: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Set the phone down on its screen.
      • Using tweezers, unplug the small vibrator connector from its socket on the motherboard.
      Ask FixBot
    2. HTC HD2 Vibrator Replacement: step 6, image 1 of 1
      • Pull the vibrator motor from the phone.
      Ask FixBot
Author
with
Nathan Puchalski
813 Reputation
5 Guides authored
Cal Poly, Team 24-55, Amido Spring 2011 Member of Cal Poly, Team 24-55, Amido Spring 2011
CPSU-AMIDO-S11S24G55
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 84
All Time: 6,454
