Up to 20% off select tools
HTC HD2 Motherboard Replacement
Views: 17K
View statistics:
Past 24 Hours:
Past 7 Days:
24
Past 30 Days:
107
All Time:
16,553
Comments: 2
2 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 15
15 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
  • T5 Torx Screwdriver
    4.9
  • Spudger
    4.9
  • Tweezers
Introduction
Go to step 1 ↓
This guide will assist you in removing the motherboard and rigid flex board in the HTC HD2.
    1. HTC HD2 Motherboard Replacement, Battery: step 1, image 1 of 1
      • Carefully pull the rear cover from the back of the phone.
      • Place a finger beneath the small lip on the left side of the battery.
      Ask FixBot
    2. HTC HD2 Motherboard Replacement: step 2, image 1 of 2 HTC HD2 Motherboard Replacement: step 2, image 2 of 2
      • Lay the phone down on it's screen.
      • Lift up on the lip and pull the battery from the phone.
      Ask FixBot
    1. HTC HD2 Motherboard Replacement, Midframe: step 3, image 1 of 2 HTC HD2 Motherboard Replacement, Midframe: step 3, image 2 of 2
      • Remove the four black 3.5mm T5 screws from the back of the phone.
      Ask FixBot
    2. HTC HD2 Motherboard Replacement: step 4, image 1 of 2 HTC HD2 Motherboard Replacement: step 4, image 2 of 2
      • Insert the flat end of a spudger between the midframe and the display.
      • Slide the spudger along the seam between the frame and the display.
      • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
      • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
      • As it releases, pull the midframe away from the phone.
      • The volume control tab may fall off during removal. It can be easily reattached.
      Ask FixBot
    1. HTC HD2 Motherboard Replacement, Vibrator: step 5, image 1 of 2 HTC HD2 Motherboard Replacement, Vibrator: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Set the phone down on its screen.
      • Using tweezers, unplug the small vibrator connector from its socket on the motherboard.
      Ask FixBot
    2. HTC HD2 Motherboard Replacement: step 6, image 1 of 1
      • Pull the vibrator motor from the phone.
      Ask FixBot
    1. HTC HD2 Motherboard Replacement, Earpiece Speaker: step 7, image 1 of 3 HTC HD2 Motherboard Replacement, Earpiece Speaker: step 7, image 2 of 3 HTC HD2 Motherboard Replacement, Earpiece Speaker: step 7, image 3 of 3
      • Disconnect the small speaker cable from its socket on the motherboard.
      • Remove the earpiece speaker from the phone.
      Ask FixBot
    1. HTC HD2 Motherboard Replacement, Motherboard: step 8, image 1 of 2 HTC HD2 Motherboard Replacement, Motherboard: step 8, image 2 of 2
      • Remove five T5 Torx screws from the motherboard.
      Ask FixBot
    2. HTC HD2 Motherboard Replacement: step 9, image 1 of 3 HTC HD2 Motherboard Replacement: step 9, image 2 of 3 HTC HD2 Motherboard Replacement: step 9, image 3 of 3
      • Disconnect the flash cable from its socket at the bottom of the motherboard.
      • Carefully pull the flash cable from its slot in the side of the phone.
      Ask FixBot
    3. HTC HD2 Motherboard Replacement: step 10, image 1 of 3 HTC HD2 Motherboard Replacement: step 10, image 2 of 3 HTC HD2 Motherboard Replacement: step 10, image 3 of 3
      • Pull the camera flash and cover off of the board.
      • You may need to peel back the sticker that sits behind the battery.
      • Work carefully. Excessive force can damage the camera or motherboard.
      Ask FixBot
    4. HTC HD2 Motherboard Replacement: step 11, image 1 of 3 HTC HD2 Motherboard Replacement: step 11, image 2 of 3 HTC HD2 Motherboard Replacement: step 11, image 3 of 3
      Buy
      • Now locate the coaxial bluetooth cable that connects the top and bottom boards of the phone.
      • Use tweezers to pop both ends of the cable from the boards and remove it completely.
      Ask FixBot
    5. HTC HD2 Motherboard Replacement: step 12, image 1 of 3 HTC HD2 Motherboard Replacement: step 12, image 2 of 3 HTC HD2 Motherboard Replacement: step 12, image 3 of 3
      • Now find the AP FPC, one of the smallest connectors on the bottom board.
      • Pop the small black tab up using tweezers, then unplug the cable.
      Ask FixBot
    6. HTC HD2 Motherboard Replacement: step 13, image 1 of 3 HTC HD2 Motherboard Replacement: step 13, image 2 of 3 HTC HD2 Motherboard Replacement: step 13, image 3 of 3
      • This step is pretty much irreversible, so do not do this unless you absolutely have to.
      • Remember peeling back part of that big sticker in the middle? Now you get to take it all the way off.
      • This may take some time, and the use of the tweezers, but keep at it until the whole sticker is off.
      Ask FixBot
    7. HTC HD2 Motherboard Replacement: step 14, image 1 of 1
      • Now find the GPS board in the upper left hand corner of the phone.
      • Disconnect the white cable from its socket on the motherboard.
      • The cable does not need to be unplugged from the main bottom board.
      • This cable is connected to the underside of the bottom board. If it is detached, be sure to reconnect it before reassembling the phone.
      Ask FixBot
    8. HTC HD2 Motherboard Replacement: step 15, image 1 of 3 HTC HD2 Motherboard Replacement: step 15, image 2 of 3 HTC HD2 Motherboard Replacement: step 15, image 3 of 3
      • If this step does not progress easily, check to see that there are no screws still holding the board in place.
      • With the cable removed, pop the GPS board out of the phone using tweezers.
      Ask FixBot
    9. HTC HD2 Motherboard Replacement: step 16, image 1 of 3 HTC HD2 Motherboard Replacement: step 16, image 2 of 3 HTC HD2 Motherboard Replacement: step 16, image 3 of 3
      • Using a spudger, begin to pry the copper colored board in the middle away from the phone to loosen it.
      • Also pry the small piece that runs under where the volume selector is on the full phone.
      Ask FixBot
    10. HTC HD2 Motherboard Replacement: step 17, image 1 of 3 HTC HD2 Motherboard Replacement: step 17, image 2 of 3 HTC HD2 Motherboard Replacement: step 17, image 3 of 3
      • There is a connecter cable under the main board, so do not pull it all the way off right away.
      • Gently pop both the top and bottom boards off of the phone, and turn them over to the left
      Ask FixBot
    11. HTC HD2 Motherboard Replacement: step 18, image 1 of 2 HTC HD2 Motherboard Replacement: step 18, image 2 of 2
      • With the back of the main board exposed, flip up the little brown lever at the end of the connector and unplug the final cable that connects it to the main board.
      Ask FixBot
4 other people completed this guide.
Author
with
Nathan Puchalski
813 Reputation
5 Guides authored
Cal Poly, Team 24-55, Amido Spring 2011 Member of Cal Poly, Team 24-55, Amido Spring 2011
CPSU-AMIDO-S11S24G55
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 107
All Time: 16,553
