HTC HD2 Earpiece Speaker Replacement
    1. HTC HD2 Earpiece Speaker Replacement, Battery: step 1, image 1 of 1
      • Carefully pull the rear cover from the back of the phone.
      • Place a finger beneath the small lip on the left side of the battery.
      Ask FixBot
    2. HTC HD2 Earpiece Speaker Replacement: step 2, image 1 of 2 HTC HD2 Earpiece Speaker Replacement: step 2, image 2 of 2
      • Lay the phone down on it's screen.
      • Lift up on the lip and pull the battery from the phone.
      Ask FixBot
    1. HTC HD2 Earpiece Speaker Replacement, Midframe: step 3, image 1 of 2 HTC HD2 Earpiece Speaker Replacement, Midframe: step 3, image 2 of 2
      • Remove the four black 3.5mm T5 screws from the back of the phone.
      Ask FixBot
    2. HTC HD2 Earpiece Speaker Replacement: step 4, image 1 of 2 HTC HD2 Earpiece Speaker Replacement: step 4, image 2 of 2
      • Insert the flat end of a spudger between the midframe and the display.
      • Slide the spudger along the seam between the frame and the display.
      • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
      • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
      • As it releases, pull the midframe away from the phone.
      • The volume control tab may fall off during removal. It can be easily reattached.
      Ask FixBot
    1. HTC HD2 Earpiece Speaker Replacement, Earpiece Speaker: step 5, image 1 of 3 HTC HD2 Earpiece Speaker Replacement, Earpiece Speaker: step 5, image 2 of 3 HTC HD2 Earpiece Speaker Replacement, Earpiece Speaker: step 5, image 3 of 3
      • Disconnect the small speaker cable from its socket on the motherboard.
      • Remove the earpiece speaker from the phone.
      Ask FixBot
Nathan Puchalski
813 Reputation
5 Guides authored
Cal Poly, Team 24-55, Amido Spring 2011 Member of Cal Poly, Team 24-55, Amido Spring 2011
CPSU-AMIDO-S11S24G55
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 103
All Time: 5,493
