Tools
Introduction
Go to step 1 ↓Do you need to access the inner components of your device? Consider using this guide to remove the back cover of your device.
Apply pressure along the bottom of the white panel containing the camera and push upwards.
Remove the black protective piece of plastic by sliding it upwards.
Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides.
Either remove the sticker or jam the screwdriver into the screw, and remove the screw.
Remove the protective panel by sliding it upwards.
2 other people completed this guide.
