Up to 20% off select tools
HTC Excalibur Battery Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
95
All Time:
2,723
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
Replacing the battery of an HTC EXCA100 is a simple process, requiring no tools.
    1. HTC Excalibur Battery Replacement, Battery: step 1, image 1 of 1
      • Power the phone off. Remove the back cover of the Phone, exposing the battery.
      • Grasp the battery by the two indents on either side of it, near the bottom. Lift up, pulling the battery loose. Remove the battery completely.
      Ask FixBot
    2. HTC Excalibur Battery Replacement: step 2, image 1 of 1
      • Take the new battery and orient it correctly -- the arrow should be facing towards the camera lens, face up.
      • Insert the battery at an angle, pushing the battery in until it is aligned on the top edge. Push the rest of the battery in, snapping it into place.
      • Reattach the battery cover, and power up your phone.
      Ask FixBot
Author
with
Ian Mitchell
142 Reputation
5 Guides authored
Cal Poly, Team 25-27, Garner Spring 2011 Member of Cal Poly, Team 25-27, Garner Spring 2011
CPSU-GARNER-S11S25G27
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 95
All Time: 2,723
