HTC Evo 4G Rear Inner Frame Replacement
    1. HTC Evo 4G Rear Inner Frame Replacement, Rear Panel: step 1, image 1 of 1
      • Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
      • Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
      Ask FixBot
    2. HTC Evo 4G Rear Inner Frame Replacement: step 2, image 1 of 1
      • Lift the rear panel off of the inner rear frame.
      Ask FixBot
    1. HTC Evo 4G Rear Inner Frame Replacement, Battery: step 3, image 1 of 2 HTC Evo 4G Rear Inner Frame Replacement, Battery: step 3, image 2 of 2
      • Using the tip of your finger, lift the battery from the end closest to the camera.
      • Remove the battery from the rear inner frame.
      Ask FixBot
    1. HTC Evo 4G Rear Inner Frame Replacement, MicroSD card: step 4, image 1 of 1
      • Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
      • The retainer will move about 1 mm and stop. Do not attempt to completely remove the MicroSD card retainer.
      Ask FixBot
    2. HTC Evo 4G Rear Inner Frame Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to carefully pull the MicroSD card out of its slot in the inner rear frame.
      Ask FixBot
    1. HTC Evo 4G Rear Inner Frame Replacement, Rear Inner Frame: step 6, image 1 of 1
      • Remove six T5 Torx screws securing the rear inner frame to the inner case.
      Ask FixBot
    2. HTC Evo 4G Rear Inner Frame Replacement: step 7, image 1 of 1
      • Gently insert an iPod opening tool between the rear inner frame and its plastic surround near the Micro HDMI port.
      • Carefully pry the top edge of the rear inner frame away from the front surround of the Evo.
      Ask FixBot
    3. HTC Evo 4G Rear Inner Frame Replacement: step 8, image 1 of 2 HTC Evo 4G Rear Inner Frame Replacement: step 8, image 2 of 2
      • Insert the iPod opening tool between the rear inner frame and its plastic surround and pry up at several points along the left edge of the Evo.
      Ask FixBot
    4. HTC Evo 4G Rear Inner Frame Replacement: step 9, image 1 of 3 HTC Evo 4G Rear Inner Frame Replacement: step 9, image 2 of 3 HTC Evo 4G Rear Inner Frame Replacement: step 9, image 3 of 3
      • Continue the prying procedure, now focusing on detaching the plastic surround from the bottom of the Evo.
      • Pry up the rear inner frame along the right edge using the method described in previous steps.
      • Eventually work around the entire perimeter of the rear inner frame until it is lifted slightly from the inner case.
      Ask FixBot
    5. HTC Evo 4G Rear Inner Frame Replacement: step 10, image 1 of 1
      • Remove the rear inner frame from the rest of the Evo.
      Ask FixBot
9 other people completed this guide.
1 Guide Comment
You may want people to also know they have to remove the lcd panel and the rear speaker to install them in their new rear inner panel.
Tony Stone - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 106
All Time: 12,765
