HTC Evo 4G MicroSD card Replacement
    1. HTC Evo 4G MicroSD card Replacement, Rear Panel: step 1, image 1 of 1
      • Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
      • Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
      Ask FixBot
    2. HTC Evo 4G MicroSD card Replacement: step 2, image 1 of 1
      • Lift the rear panel off of the inner rear frame.
      Ask FixBot
    1. HTC Evo 4G MicroSD card Replacement, Battery: step 3, image 1 of 2 HTC Evo 4G MicroSD card Replacement, Battery: step 3, image 2 of 2
      • Using the tip of your finger, lift the battery from the end closest to the camera.
      • Remove the battery from the rear inner frame.
      Ask FixBot
    1. HTC Evo 4G MicroSD card Replacement, MicroSD card: step 4, image 1 of 1
      • Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
      • The retainer will move about 1 mm and stop. Do not attempt to completely remove the MicroSD card retainer.
      Ask FixBot
    2. HTC Evo 4G MicroSD card Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to carefully pull the MicroSD card out of its slot in the inner rear frame.
      Ask FixBot
7 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 44
All Time: 10,959
