Introduction
Use this guide to replace the front-facing camera.
Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
Using the tip of your finger, lift the battery from the end closest to the camera.
Remove the battery from the rear inner frame.
Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
Remove six T5 Torx screws securing the rear inner frame to the inner case.
Continue the prying procedure, now focusing on detaching the plastic surround from the bottom of the Evo.
Pry up the rear inner frame along the right edge using the method described in previous steps.
Eventually work around the entire perimeter of the rear inner frame until it is lifted slightly from the inner case.
Remove the single Phillips screw securing the motherboard to the inner case near the headphone jack.
Tool used on this step:Tweezers$4.99
Using the tip of an iPod opening tool, flip up the front-facing camera ribbon cable retaining flap.
Be very careful and gentle with these flaps. They are very easy to break or dislodge and equally difficult to reinstall.
Use a pair of tweezers to pull the front-facing camera ribbon cable straight out of its socket.
Gently lift the front-facing camera out of its recess in the inner case and remove it from the Evo.
3 other people completed this guide.
