HTC Evo 3D Vibrate Mechanism Replacement
  1. HTC Evo 3D Vibrate Mechanism Replacement, Vibrate Mechanism: step 1, image 1 of 3 HTC Evo 3D Vibrate Mechanism Replacement, Vibrate Mechanism: step 1, image 2 of 3 HTC Evo 3D Vibrate Mechanism Replacement, Vibrate Mechanism: step 1, image 3 of 3
    • Remove the outer casing of the phone with your hands by prying and lifting at the latch.
  2. HTC Evo 3D Vibrate Mechanism Replacement: step 2, image 1 of 2 HTC Evo 3D Vibrate Mechanism Replacement: step 2, image 2 of 2
    • Remove the battery with your hands, lifting at the marked area.
  3. HTC Evo 3D Vibrate Mechanism Replacement: step 3, image 1 of 1
    • Remove the SD card
    • Remove the four T5 screws using the corresponding screwdriver.
    • Remove the two J000 screws using the corresponding screwdriver.
  4. HTC Evo 3D Vibrate Mechanism Replacement: step 4, image 1 of 2 HTC Evo 3D Vibrate Mechanism Replacement: step 4, image 2 of 2
    • With the battery removed, the inner case of the phone can now be removed.
    • Using the plastic opening tool, pry the inner case off at the marked area. Continue prying around the entire perimeter of the phone.
    • This will remove the inner case, and allow access into the inner portion of the phone.
    • Be careful not rip or damage the ribbons inside this shell.
  5. HTC Evo 3D Vibrate Mechanism Replacement: step 5, image 1 of 3 HTC Evo 3D Vibrate Mechanism Replacement: step 5, image 2 of 3 HTC Evo 3D Vibrate Mechanism Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • The vibrating mechanism is located on the motherboard, on the right.
    • The marked part is the vibrating mechanism.
    • To remove the vibrating mechanism, use the tweezers to securely hold the wire and tug on it.
    • The vibrating unit can then be disconnected from the motherboard using the tweezers, grasping the white part.
James Burke
245 Reputation
2 Guides authored
USF Tampa, Team 14-20, Meier Fall 2015 Member of USF Tampa, Team 14-20, Meier Fall 2015
USFT-MEIER-F15S14G20
5 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 72
All Time: 553
