HTC Evo 3D Speaker Replacement
  1. HTC Evo 3D Speaker Replacement, Speaker: step 1, image 1 of 3 HTC Evo 3D Speaker Replacement, Speaker: step 1, image 2 of 3 HTC Evo 3D Speaker Replacement, Speaker: step 1, image 3 of 3
    • Remove the outer casing of the phone with your hands by prying and lifting at the latch.
  2. HTC Evo 3D Speaker Replacement: step 2, image 1 of 2 HTC Evo 3D Speaker Replacement: step 2, image 2 of 2
    • Remove the battery with your hands, lifting at the marked area.
    • Remove the SD card by pulling down on the bottom of the card.
  3. HTC Evo 3D Speaker Replacement: step 3, image 1 of 1
    • Remove the four T5 screws using the cooresponding screwdriver.
    • Remove the two J000 screws using the cooresponding screwdriver.
  4. HTC Evo 3D Speaker Replacement: step 4, image 1 of 2 HTC Evo 3D Speaker Replacement: step 4, image 2 of 2
    • With the battery removed, the inner case of the phone can now be removed.
    • Using the plastic opening tool, pry the inner case off at the marked area. Continue prying around the entire perimeter of the phone.
    • This will remove the inner case, and allow access into the inner portion of the phone.
    • The marked part in the second photo is the speaker.
  5. HTC Evo 3D Speaker Replacement: step 5, image 1 of 3 HTC Evo 3D Speaker Replacement: step 5, image 2 of 3 HTC Evo 3D Speaker Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • The speaker can be loosened from its glue with the spudger.
    • Pry from the bottom with constant pressure to loosen one end of the speaker.
    • When the speaker is sufficiently loosened, completely remove it by grabbing it with the precision tweezers.
  6. HTC Evo 3D Speaker Replacement: step 6, image 1 of 1
    • With the old speaker removed, insert the new speaker in the same place.
    • When reinserting the new speaker, be sure that the golden contacts (As previously marked) are facing up.
To reassemble your device, follow these instructions in reverse order but with a new speaker.
James Burke
245 Reputation
2 Guides authored
USF Tampa, Team 14-20, Meier Fall 2015 Member of USF Tampa, Team 14-20, Meier Fall 2015
USFT-MEIER-F15S14G20
5 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 60
All Time: 600
