HTC Evo 3D Motherboard Replacement
    1. HTC Evo 3D Motherboard Replacement, Motherboard: step 1, image 1 of 3 HTC Evo 3D Motherboard Replacement, Motherboard: step 1, image 2 of 3 HTC Evo 3D Motherboard Replacement, Motherboard: step 1, image 3 of 3
      • Remove the outer casing of the phone with your hands by prying and lifting at the latch.
      Ask FixBot
    2. HTC Evo 3D Motherboard Replacement: step 2, image 1 of 2 HTC Evo 3D Motherboard Replacement: step 2, image 2 of 2
      • Remove the battery with your hands, lifting at the marked area.
      • Remove the SD card by gently pulling down on the bottom of the card.
      Ask FixBot
    3. HTC Evo 3D Motherboard Replacement: step 3, image 1 of 1
      • Remove the four T5 screws using the corresponding screwdriver.
      • Remove the two J000 screws using the corresponding screwdriver.
      Ask FixBot
    4. HTC Evo 3D Motherboard Replacement: step 4, image 1 of 2 HTC Evo 3D Motherboard Replacement: step 4, image 2 of 2
      • With the battery, SD card, and screws removed, the inner case of the phone can now be removed.
      • Using the plastic opening tool, pry the inner case off at the marked area. Continue prying around the entire perimeter of the phone.
      • This will remove the inner case, and allow access into the inner portion of the phone.
      • Be sure not to rip or damage the ribbons inside this shell.
      Ask FixBot
    5. HTC Evo 3D Motherboard Replacement: step 5, image 1 of 3 HTC Evo 3D Motherboard Replacement: step 5, image 2 of 3 HTC Evo 3D Motherboard Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Pictured here is the motherboard.
      • Using precision tweezers, remove the flash mechanism by prying the sides of the piece.
      Ask FixBot
    6. HTC Evo 3D Motherboard Replacement: step 6, image 1 of 3 HTC Evo 3D Motherboard Replacement: step 6, image 2 of 3 HTC Evo 3D Motherboard Replacement: step 6, image 3 of 3
      • Next we will remove the vibration mechanism shown here.
      • Using precision tweezers or fingers, gently pull on the wires connecting the vibration mechanism to the motherboard.
      • The piece should come loose easily.
      Ask FixBot
    7. HTC Evo 3D Motherboard Replacement: step 7, image 1 of 3 HTC Evo 3D Motherboard Replacement: step 7, image 2 of 3 HTC Evo 3D Motherboard Replacement: step 7, image 3 of 3
      • The next step is to disconnect all ribbons attached to the motherboard.
      • Begin by using tweezers to remove the plastic covering the ribbons.
      • Each ribbon needs to be removed by unlocking the white tab and pulling on the ribbon.
      • Unlock by lifting the white tab directly up.
      • The ribbons easily rip and require careful handling.
      Ask FixBot
    8. HTC Evo 3D Motherboard Replacement: step 8, image 1 of 2 HTC Evo 3D Motherboard Replacement: step 8, image 2 of 2
      • At this point the motherboard is almost fully detached.
      • Lift the motherboard and using precision tweezers, peel up the insulation cover on the bottom left corner.
      Ask FixBot
    9. HTC Evo 3D Motherboard Replacement: step 9, image 1 of 3 HTC Evo 3D Motherboard Replacement: step 9, image 2 of 3 HTC Evo 3D Motherboard Replacement: step 9, image 3 of 3
      • Disconnect the two ribbons on the backside of the mother board using precision tweezers.
      • Disconnect the Cellular/WIFI antenna by pulling directly up on the black wire.
      • The motherboard will now be free from the rest of the phone.
      Ask FixBot
3 other people completed this guide.
Matthew Pope
441 Reputation
2 Guides authored
USF Tampa, Team 14-20, Meier Fall 2015 Member of USF Tampa, Team 14-20, Meier Fall 2015
USFT-MEIER-F15S14G20
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 31
All Time: 1,351
