Up to 20% off select tools
HTC Droid Eris Midframe Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
6
Past 30 Days:
68
All Time:
991
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Student In Progress
This guide is being worked on by hardworking students.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
This guide will teach you how to replace/install the midframe of your HTC Droid Eris phone.
    1. HTC Droid Eris Midframe Replacement, Battery: step 1, image 1 of 2 HTC Droid Eris Midframe Replacement, Battery: step 1, image 2 of 2
      • Place the device on a flat surface with the headphone outlet/jack facing away from you.
      • Place one of your fingers on the opposite corner of the headphone outlet/jack where there is a sliver of space. Be sure not to touch the front screen.
      • Next, pull the back cover upwards and off. If this feels difficult, use the spudger, and wedge it between the covers to pry off.
      Ask FixBot
    2. HTC Droid Eris Midframe Replacement: step 2, image 1 of 2 HTC Droid Eris Midframe Replacement: step 2, image 2 of 2
      • Once the cover is off, lay the device on a flat surface with the screen facing downward. Use one hand to hold the device in place with the half-moon gap facing away from you [marked].
      • The square piece in the center of the phone is the battery. With your free hand, stick one of your fingers in the marked gap. Pull gently upwards towards you to remove.
      • If the battery is not coming out with this technique, use the iFixit plastic opening tool to pop it out of its holdings.
      Ask FixBot
    1. HTC Droid Eris Midframe Replacement, Midframe: step 3, image 1 of 2 HTC Droid Eris Midframe Replacement, Midframe: step 3, image 2 of 2
      • At the lower right hand corner of the phone use one hand to hold the device in place and use your finger to push the micro SD card inwards until you hear a "click" sound and it pops out.
      • If that method is difficult, use the plastic opening tool or spudger to push the micro SD card inwards and it will make a "click" sound and pop out.
      Ask FixBot
    2. HTC Droid Eris Midframe Replacement: step 4, image 1 of 2 HTC Droid Eris Midframe Replacement: step 4, image 2 of 2
      • Use the T4 screwdriver to remove the three .05 mm screws from the back cover.
      Ask FixBot
    3. HTC Droid Eris Midframe Replacement: step 5, image 1 of 2 HTC Droid Eris Midframe Replacement: step 5, image 2 of 2
      • Use the plastic opening tool and place it in the gap by the chrome bezels which are located on both sides of the device. Pull the plastic opening tool to pry plastic case apart. Start prying open the device and work around the seam of the phone in a clockwise direction.
      • DON’T BREAK THE CLIPS (you can damage the frame this way). Pry it gently until you hear it click and start to see it open.
      • Remove the midframe.
      Ask FixBot
Author
with
Elizabeth Ofori
648 Reputation
6 Guides authored
SUNY Cortland, Team 1-2, Getto Spring 2013 Member of SUNY Cortland, Team 1-2, Getto Spring 2013
SUNYCORT-GETTO-S13S1G2
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 68
All Time: 991
