HTC Droid Eris Battery Replacement
    1. HTC Droid Eris Battery Replacement, Battery: step 1, image 1 of 2 HTC Droid Eris Battery Replacement, Battery: step 1, image 2 of 2
      • Place the device on a flat surface with the headphone outlet/jack facing away from you.
      • Place one of your fingers on the opposite corner of the headphone outlet/jack where there is a sliver of space. Be sure not to touch the front screen.
      • Next, pull the back cover upwards and off. If this feels difficult, use the spudger, and wedge it between the covers to pry off.
      Ask FixBot
    2. HTC Droid Eris Battery Replacement: step 2, image 1 of 2 HTC Droid Eris Battery Replacement: step 2, image 2 of 2
      • Once the cover is off, lay the device on a flat surface with the screen facing downward. Use one hand to hold the device in place with the half-moon gap facing away from you [marked].
      • The square piece in the center of the phone is the battery. With your free hand, stick one of your fingers in the marked gap. Pull gently upwards towards you to remove.
      • If the battery is not coming out with this technique, use the iFixit plastic opening tool to pop it out of its holdings.
      Ask FixBot
Elizabeth Ofori
648 Reputation
6 Guides authored
SUNY Cortland, Team 1-2, Getto Spring 2013 Member of SUNY Cortland, Team 1-2, Getto Spring 2013
SUNYCORT-GETTO-S13S1G2
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 101
All Time: 1,271
