HTC Desire V Vibration Motor Replacement
  1. HTC Desire V Vibration Motor Replacement, Battery: step 1, image 1 of 3 HTC Desire V Vibration Motor Replacement, Battery: step 1, image 2 of 3 HTC Desire V Vibration Motor Replacement, Battery: step 1, image 3 of 3
    • Gently pry back cover away from phone.
    • If you are having difficulty you may need to use a Spudger or plastic opener.
  2. HTC Desire V Vibration Motor Replacement: step 2, image 1 of 3 HTC Desire V Vibration Motor Replacement: step 2, image 2 of 3 HTC Desire V Vibration Motor Replacement: step 2, image 3 of 3
    • Lever the battery out from the bottom end first.
    • Do not bend or puncture the battery.
  3. HTC Desire V Vibration Motor Replacement, Midframe: step 3, image 1 of 3 HTC Desire V Vibration Motor Replacement, Midframe: step 3, image 2 of 3 HTC Desire V Vibration Motor Replacement, Midframe: step 3, image 3 of 3
    • Use a Torx T5 screwdriver to unscrew and remove five 3.0 mm screws from the rear frame.
  4. HTC Desire V Vibration Motor Replacement: step 4, image 1 of 3 HTC Desire V Vibration Motor Replacement: step 4, image 2 of 3 HTC Desire V Vibration Motor Replacement: step 4, image 3 of 3
    • Use an opening tool or a spudger to gently remove the rear frame.
  5. HTC Desire V Vibration Motor Replacement, Vibration Motor: step 5, image 1 of 2 HTC Desire V Vibration Motor Replacement, Vibration Motor: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Unplug the vibration motor shown from the white plug on the motherboard.
    • You will probably need tweezers to do this.
  6. HTC Desire V Vibration Motor Replacement: step 6, image 1 of 2 HTC Desire V Vibration Motor Replacement: step 6, image 2 of 2
    • Gently remove the motor from its housing in the phone’s chassis.
    • The easiest way to do this is to lever the motor out by its rotating end using the tweezers.
William McCusker
1,096 Reputation
9 Guides authored
Clemson, Team 14-3, Shirley Winter 2015 Member of Clemson, Team 14-3, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G3
6 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 28
All Time: 536
