HTC Desire V Motherboard Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
84
All Time:
654
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide will outline how to remove the logic board assembly, including cables, from the HTC Desire V smartphone
Tools
    1. HTC Desire V Motherboard Replacement, Battery: step 1, image 1 of 3 HTC Desire V Motherboard Replacement, Battery: step 1, image 2 of 3 HTC Desire V Motherboard Replacement, Battery: step 1, image 3 of 3
      • Gently pry back cover away from phone.
      • If you are having difficulty you may need to use a Spudger or plastic opener.
      Ask FixBot
    2. HTC Desire V Motherboard Replacement: step 2, image 1 of 3 HTC Desire V Motherboard Replacement: step 2, image 2 of 3 HTC Desire V Motherboard Replacement: step 2, image 3 of 3
      • Lever the battery out from the bottom end first.
      • Do not bend or puncture the battery.
      Ask FixBot
    1. HTC Desire V Motherboard Replacement, Midframe: step 3, image 1 of 3 HTC Desire V Motherboard Replacement, Midframe: step 3, image 2 of 3 HTC Desire V Motherboard Replacement, Midframe: step 3, image 3 of 3
      • Use a Torx T5 screwdriver to unscrew and remove five 3.0 mm screws from the rear frame.
      Ask FixBot
    2. HTC Desire V Motherboard Replacement: step 4, image 1 of 3 HTC Desire V Motherboard Replacement: step 4, image 2 of 3 HTC Desire V Motherboard Replacement: step 4, image 3 of 3
      • Use an opening tool or a spudger to gently remove the rear frame.
      Ask FixBot
    1. HTC Desire V Motherboard Replacement, Button Assembly: step 5, image 1 of 2 HTC Desire V Motherboard Replacement, Button Assembly: step 5, image 2 of 2
      • Remove the connector on left side of the Navigation board by unplugging/prying the orange ribbon.
      Ask FixBot
    2. HTC Desire V Motherboard Replacement: step 6, image 1 of 2 HTC Desire V Motherboard Replacement: step 6, image 2 of 2
      • Gently unplug and remove aerial cable (black antenna) from bottom plug.
      Ask FixBot
    3. HTC Desire V Motherboard Replacement: step 7, image 1 of 2 HTC Desire V Motherboard Replacement: step 7, image 2 of 2
      • Nav Board will be stuck down by glue.
      • Pull gently from the right end of the board, being careful of its flexibility.
      Ask FixBot
    1. HTC Desire V Motherboard Replacement, Vibration Motor: step 8, image 1 of 2 HTC Desire V Motherboard Replacement, Vibration Motor: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Unplug the vibration motor shown from the white plug on the motherboard.
      • You will probably need tweezers to do this.
      Ask FixBot
    2. HTC Desire V Motherboard Replacement: step 9, image 1 of 2 HTC Desire V Motherboard Replacement: step 9, image 2 of 2
      • Gently remove the motor from its housing in the phone’s chassis.
      • The easiest way to do this is to lever the motor out by its rotating end using the tweezers.
      Ask FixBot
    1. HTC Desire V Motherboard Replacement, Motherboard Assembly: step 10, image 1 of 2 HTC Desire V Motherboard Replacement, Motherboard Assembly: step 10, image 2 of 2
      • Remove the black information sticker if this is the first time opening the handset.
      Ask FixBot
    2. HTC Desire V Motherboard Replacement: step 11, image 1 of 3 HTC Desire V Motherboard Replacement: step 11, image 2 of 3 HTC Desire V Motherboard Replacement: step 11, image 3 of 3
      Buy
      • You should now see a black ribbon cable, which was connected at the left to the Nav board, and on the right, to a gold ribbon cable which goes to the screen.
      • Unlock the gold ribbon cable connecting screen to logic board by lifting the locking tab at the back of the socket.
      • For this you may wish to use a spudger or tweezers.
      Ask FixBot
    3. HTC Desire V Motherboard Replacement: step 12, image 1 of 2 HTC Desire V Motherboard Replacement: step 12, image 2 of 2
      • Disconnect gold ribbon cable connecting screen to logic board by pulling cable out gently.
      Ask FixBot
    4. HTC Desire V Motherboard Replacement: step 13, image 1 of 3 HTC Desire V Motherboard Replacement: step 13, image 2 of 3 HTC Desire V Motherboard Replacement: step 13, image 3 of 3
      • Gently unstick black ribbon cable from the chassis.
      Ask FixBot
    5. HTC Desire V Motherboard Replacement: step 14, image 1 of 2 HTC Desire V Motherboard Replacement: step 14, image 2 of 2
      • Unscrew the 2mm silver screw from top left.
      • Use a Phillips PH00 Screwdriver for this.
      Ask FixBot
    6. HTC Desire V Motherboard Replacement: step 15, image 1 of 2 HTC Desire V Motherboard Replacement: step 15, image 2 of 2
      • Gently pry logic board from the casing by lifting the left side up, as if there was a hinge on the right, folding it over the right edge where you will see a gold/orange ribbon cable.
      Ask FixBot
    7. HTC Desire V Motherboard Replacement: step 16, image 1 of 3 HTC Desire V Motherboard Replacement: step 16, image 2 of 3 HTC Desire V Motherboard Replacement: step 16, image 3 of 3
      • Remove the gold ribbon cable by lifting tab at the back of the socket, using a spudger or tweezers.
      Ask FixBot
    8. HTC Desire V Motherboard Replacement: step 17, image 1 of 2 HTC Desire V Motherboard Replacement: step 17, image 2 of 2
      • Gently pull the logic board to the right and it will disconnect from the chassis.
      Ask FixBot
William McCusker
1,096 Reputation
9 Guides authored
Clemson, Team 14-3, Shirley Winter 2015 Member of Clemson, Team 14-3, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G3
6 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 84
All Time: 654
