HTC Desire 826 Daughterboard Replacement
  1. HTC Desire 826 Daughterboard Replacement, Battery: step 1, image 1 of 3 HTC Desire 826 Daughterboard Replacement, Battery: step 1, image 2 of 3 HTC Desire 826 Daughterboard Replacement, Battery: step 1, image 3 of 3
    • Find a seam in the back of the device.
    • Insert the plastic spudger into the seam and pry off the back panel.
    • There will be glue, so keep prying until it comes off or you may need to heat up the edges of the device to loosen the adhesive with the iOpener.
  2. HTC Desire 826 Daughterboard Replacement: step 2, image 1 of 3 HTC Desire 826 Daughterboard Replacement: step 2, image 2 of 3 HTC Desire 826 Daughterboard Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the 4.0 mm screw above the battery with a T5 Torx screwdriver.
    • Remove the metal bracket with the tweezers.
  3. HTC Desire 826 Daughterboard Replacement: step 3, image 1 of 1
    • Disconnect the battery cable from the motherboard with the tweezers.
  4. HTC Desire 826 Daughterboard Replacement: step 4, image 1 of 2 HTC Desire 826 Daughterboard Replacement: step 4, image 2 of 2
    • Lift the battery with a plastic spudger and remove it from the device.
  5. HTC Desire 826 Daughterboard Replacement, Daughterboard: step 5, image 1 of 1
    • Use a T5 Torx screwdriver to remove the two 4.0 mm screws in the bottom corners of the device.
  6. HTC Desire 826 Daughterboard Replacement: step 6, image 1 of 1
    • Use a T5 Torx screwdriver to remove one screw connected to the daughterboard.
  7. HTC Desire 826 Daughterboard Replacement: step 7, image 1 of 2 HTC Desire 826 Daughterboard Replacement: step 7, image 2 of 2
    • Remove the interconnect ribbon cable by flipping up the black tab of the ZIF connector and pulling out the cable with your fingers.
    • Remove the daughterboard.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 29
All Time: 303
